Check the harness connector for corrosion. Even if they look fine hit the pins with a little fine grit sandpaper, clean it out and put a little dielectric grease in there.
I had this code pop up years ago. I unplugged the MAF, re plugged it, and the code was gone and never came back. So, check the plug.
