FordMan77
Check the fuse for the cigarette lighter. This is also tied to the OBD port IIRC. Beyond that, I'd double check all the underhood fuses and grounds to be sure nothing is blown/loose. If everything is connected properly there should be no reason it won't start. I had the engine out of mine for a while and it fired right up after reassembly with no issues.
