Thread: 2000 GT 3.8 N/A, starts, then shuts off??
Results 1 to 19 of 19
Threaded View
  1. #1 2000 GT 3.8 N/A, starts, then shuts off??
    Jan 2017
    Lehighton, PA
    Hi all. I'm new here, and I'm hoping ya'll can help me. I have a 2000 GT 3.8L N/A with 124k on it. Its in decent shape, and was running like a clock (no loss of power, no stalling, ran GREAT) until yesterday. I went out to use it to go to the store, and, it had been sitting for about 3 days in cold PA temperatures (around 30 deg. day, 20 at night). It started first try like always, and ran for about 3 minutes, because I wanted to warm it up some. Then, as I placed it into Reverse, it stumbled, and just shut off! I put it in Neutral, and it started back up, but shut right back off. This kept up even when trying to floor the gas pedal, it would just run for additional 2 seconds. I finally got it back into its parking space after quickly starting it, and throwing it into gear with the gas floored, and it dying right away. Then, low and behold, after about 10 times, I started it, the stumble went away, and it kept running....but the RPM gauge was wobbling some between idle and 1,000 RPM, like it is not idling quite right. I have not tried to start it since or drive it because I do not trust it.
    Now, some background. The SES light has been on for quite some time, but I have known what that issue is/was. Unfortunately for me, it is a CA equipped car and has a Smog Pump. The pump is no good from all the diagnosis I have performed, so I replaced it with a junkyard unit trying to save money, but it had water in it (typical issue I found out), and blew the fuses for the EVAP system. So the light stays on, and it only threw 2 codes for that system, which I have known for a year, doesn't bother me. Also, the car also would intermittently when hot would misfire Cylinder 4, so I changed the plugs, wires, and that Coil, but it still does it, but only Occasionally. It will run real rough on a hot re-start, but if you play with gas and let it idle for a minute or two, she smooths out, and drives like a dream again. That was going on for months too, and I let go as a fluke, and kind of knowing in the back of my mind that the Ignition Module was GOING, but not BAD yet. ANYWAY. after the stalling incident yesterday, a new code now arose, for the Mass Air Meter. With no history of power loss, rough idle, or anything like that, would a MAF just go like that and cause the car to die out like this?? I was thinking the Ignition Module finally gave out, since the temperature outside has been so cold, but then why would it have started in the first place? Maybe it got warm, rose resistance and failed? I don't know?? It's not Supercharged, so I know it's not a Fuel Pump Resistor, and the Fuel Pump IS running when the key is turned everytime, and I get NO Security light when the car dies, or starts, and had no trouble with the key before, as it is the original key to the car, and the Ignition Switch is fairly new in the new (the switch, not the cylinder). Should I check the fuel pressure first, or start with the Ignition Module since I already had issues with Misfires?? Or look at the MAF, unhook it, and see what happens?? Some say about the Cat being clogged, but wouldn't I have noticed a loss of power, or the rotten egg smell before?? This thing had PLENTY of power before. I'm at a loss after reading all of the possibilities for this condition with these cars ladies and gentlemen. Please help! Thanks!!!!
    Added Note: The Air Filter, Fuel Filter, EGR Valve, and PCV Valve are all also new.
  1. intermittently car starts and shuts right off
    By Dee23 in forum General Grand Prix Discussion
    Last Post: 08-01-2014, 07:19 PM
  2. 02 Starts and then Shuts Off?
    By KitRae in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-12-2013, 12:20 PM
  3. 03 Top Swap now starts but shuts off while driving on occasion
    By The Guz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-31-2012, 05:20 AM
  4. Car starts 3-4 seconds and shuts off. P0122 and P1122
    By Brooks in forum General Tech Discussion
    Last Post: 08-28-2012, 07:47 PM
  5. Car starts then as its about to Idle, car shuts off
    By fasterthenu2000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2009, 05:51 PM
