Thread: HELP!!Engine turns but doesn't crank
Results 1 to 9 of 9
  1. #1 HELP!!Engine turns but doesn't crank
    Apr 2013
    seguin
    the other day on my lunch break I got in my car,started it and it died immediately and won't turn over..it seemed like it was the starter so I changed it...didn't fix it.checked all the fuses and all good.im getting fuel pressure from the rail...one of the coils(#3-6) were cracked and hot as hell so I changed it and still nothing...but the one thing I noticed is that the 3-6 coil is hot as hell but the other 2 are ice cold when I get done trying to crank it...Ignition control module maybe?I'm not getting any codes,engine light or anything....any help or info would be great!!!Im broke now and can't keep spending $$ on things that aren't the problem..THANK U
    Sent from my SM-J327P using Tapatalk
  2. #2 Re: HELP!!Engine turns but doesn't crank
    So it turns over and cranks the engine but doesn't fire?
    One really hot coil could point to a short in the ICM.
  3. #3 Re: HELP!!Engine turns but doesn't crank
    Apr 2013
    seguin
    ya it will keep cranking but won't even attempt to fire or turn over.and the one coil gets really really hot.and that's the one I just replaced
  4. #4 Re: HELP!!Engine turns but doesn't crank
    icm can be costly. i'd hit a junk yard and snag one. or used off ebay or something.
  5. #5 Re: HELP!!Engine turns but doesn't crank
    Apr 2013
    seguin
    ya.$100 and I work at O'Reilly..lol too much...got a friend getting one from a yard tomorrow hopefully..does it sound like it's the ICM?
  6. #6 Re: HELP!!Engine turns but doesn't crank
    it sure could be, one hot coil dont sound right at all.
  7. #7 Re: HELP!!Engine turns but doesn't crank
    Apr 2013
    seguin
    ya it was the ICM.changed it and runs great now
  8. #8 Re: HELP!!Engine turns but doesn't crank
    junk yard parts save the day once again....
  9. #9 Re: HELP!!Engine turns but doesn't crank
    Apr 2013
    seguin
    thx for the help
  1. Car Turns Over Freely - Doesn't Start
    By CNorell145 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-09-2014, 07:02 PM
  2. Take oil cap off and engine turns off
    By MCbatt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2013, 06:32 AM
  3. Engine Starts for a second then turns off
    By gtpterp in forum Engine
    Last Post: 10-11-2011, 05:38 AM
  4. Engine turns over but will not start
    By rockytop104 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-04-2010, 10:17 AM
  5. Car runs fine but doesn't start the first time i turn the key.. Needs a few turns..
    By azmattaz06 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-28-2009, 02:18 AM
