Thread: 37 foot pounds plus 120 degrees
Results 1 to 20 of 24
  1. #1 37 foot pounds plus 120 degrees
    Oct 2013
    Clovis, California USA
    How do you guys arrive at that when installing your 3800 heads? You guys use an angle gauge?
  2. #2 Re: 37 foot pounds plus 120 degrees
    i used a degree wheel for bolts, its like 10 bucks here at the parts store.
  3. #3 Re: 37 foot pounds plus 120 degrees
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    120 degrees would be from 12 to 4 o'clock
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  4. #4 Re: 37 foot pounds plus 120 degrees
    May 2008
    Schuyler, NE
    I've always just estimated.
  5. #5 Re: 37 foot pounds plus 120 degrees
    Mar 2017
    Internet
    90 degrees is a right angle. and 180 is straight in the other direction.. I do the same as GTPower.
  6. #6 Re: 37 foot pounds plus 120 degrees
    Antioch, IL
    big boys use studs
    2009 Challenger SRT8
    Expert at being gay.
  7. #7 Re: 37 foot pounds plus 120 degrees
    Mar 2017
    Internet
    Quote Originally Posted by ItHurtz View Post
    big boys use studs
    So you know nothing about them Corey? hahaha
  8. #8 Re: 37 foot pounds plus 120 degrees
    Nov 2011
    NY
    37# +120* is like 65+lbs easily... Lol, never understood the degree reference when just providing torque spec is sufficient... For the record, I guess too, like that one, if +120, I would just go 1/4 turn more and a scutch.
    Just get studs and make it easy (90lbs) hahahaha
  9. #9 Re: 37 foot pounds plus 120 degrees
    Antioch, IL
    Quote Originally Posted by BillBooost37 View Post
    In a box counts!
  10. #10 Re: 37 foot pounds plus 120 degrees
    Oct 2013
    Scottydoggs - You talking about one of these?
  11. #11 Re: 37 foot pounds plus 120 degrees
    thats it. watch a vid on how to set it up, that right angle rod needs to be set so the gauge cant spin. you need to set it up and zero it for each bolt as you go.
  12. #12 Re: 37 foot pounds plus 120 degrees
    GT Level Member mguzzo's Avatar
    Buffalo NY
    Quote Originally Posted by coolone View Post
    the torque specification is to apply the force to begin to stretch the bolt. the angle specification is the additional turn to actually stretch the bolt through its elastic phase and maximize the clamping force. from a technique point of view, the angle needs to be a smooth pull, not yank-yank-yank, so the bolt stretches then re-freezes in one continuous motion.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  13. #13 Re: 37 foot pounds plus 120 degrees
    Oct 2013
    That means if I'm using a long handle ratchet, I need to torque the angle with one big swing, or would a breaker bar be better ?
  14. #14 Re: 37 foot pounds plus 120 degrees
    breaker bar is what i used.
    im just gonna say, this bolt stretching is about the single most un natural thing ive ever done, you'd never pull on a bolt and make it this tight. how they dont snap ill never know, but it sure feels that way.
  15. #15 Re: 37 foot pounds plus 120 degrees
    Oct 2013
    ItHurtz - What's the torque spec on the threaded studs kit ?
  16. #16 Re: 37 foot pounds plus 120 degrees
    Antioch, IL
    90 for the nuts is a good number to be at.
  17. #17 Re: 37 foot pounds plus 120 degrees
    Oct 2013
    Wow, it's a good thing I asked because I've been looking at torque wrenches that only go up to 75 foot pounds.
  18. #18 Re: 37 foot pounds plus 120 degrees
    Oct 2013
    Just got back from the machine shop. The machinist there said 37 foot pounds plus 120 degrees sounds WAY TOO TIGHT. But then he said he's not a mechanic and has never torqued those rocker arms. I then went to a pro repair shop downtown and the guy there said he thinks that sounds too tight too, but he couldn't give me a definite answer. He suggested that I do some more cautious research. He suggested checking with an online Buick forum, but I told him that most Buick owners are not mechanics and that they only have questions about their power lumbar support.
    The one thing I find interesting though is that the re-usable Competition Cams rocker arm bolts have a spec of 25 foot pounds and zero degrees.
  19. #19 Re: 37 foot pounds plus 120 degrees
    Mar 2017
    Internet
    Hold up a second.
    Head bolts are 37 plus X to start..then the inner 4 bolts get more degrees.
    Rocker bolts...which you mentioned in your last post.... NO WAY, STOP THE TRUCK!!!! They are not 37 plus 120
  20. #20 Re: 37 foot pounds plus 120 degrees
    hangover park IL
    Rockers are 11ftlbs and 50° iirc
    ~James~ Psychotic Gearhead
  1. 25lb pounds cyl #4
    By jsaylor in forum General Tech Discussion
    Last Post: 08-24-2012, 10:03 AM
  2. How many pounds of boost should I be running?
    By slow94formula in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-07-2009, 01:36 PM
  3. Seven Pounds
    By SlowM90 in forum Off Topic Discussion
    Last Post: 04-03-2009, 02:21 PM
  4. Gruesome Foot! NWS (gore)
    By Preotic in forum Off Topic Discussion
    Last Post: 01-22-2009, 06:09 AM
