Hey guys I picked up a 2006 GP on Craigslist a few weeks ago. Decent body and interior and would make nice daily driver.
The previous owner, (young man in his 20s) said the water pump went out and he overheated the engine. He thought the head gasket(s) were toast. It was missing and had gas bubbling up through the coolant tank.
I assumed at least the head gaskets and possibly the heads were cracked.
I made a deal to buy it and took it home on my trailer.
I removed the heads and gaskets and took them to my engine guy. He found both head gaskets had bad spot but the head were NOT cracked on the magniflux check. The heads were checked for warpage too. That's as far as I went, I'm low on cash and looking for a super cheap driver.
I ordered new gasket kit and a new water pump and spark plug wires. So I finished this project last night. I have low idle miss on cylinder #3. The engine runs strong when given throttle but at idle it's missing. I drove the car and it runs great but when we get back to idle it's still missing....
Here is what I check so far.
1.) Confirmed I have spark to #3
2.) Confirmed the plug is not fouled (swapped the #5 plug and it still misses on #3)
3.) Confirmed I have fuel coming from the #3 injector
My next check is to see if I have a bent push rod or bad rocker? Not sure what to do after that, I suspect a bent valve or similar. I really didn't check the valves out that closely but I suspect that's where the problem lies.
Suggestions???
