Thread: Please help me save my GP!!!
Page 1 of 3 123 LastLast
Results 1 to 20 of 58
  1. #1 Please help me save my GP!!!
    Jersey
    Hello. 97 SE..147k. I took her to the gas station to fill up and then headed home. As soon as I get in the driveway I smell something burning so I immediately turned her off and inspected. Found nothing. About an hour later..It's time to go to work. I jumped in the car and turned her over. It cranked twice and completely shut off!! So I popped the hood...Coolant reservoir is full...rad is empty....And I can literally squeeze the life out of the upper and lower hoses and hear the air blowing through 😞. There's no coolant anywhere on the ground, but I see a small coolant pool in the back of the intake manifold. Someone please tell me I can fix her up and this isn't a case of hydrolock. Thank you.
  2. #2 Re: Please help me save my GP!!!
    Pull the spark plugs, see if coolant pours out.
    Check the oil level too, it might be higher because coolant is in the crankcase now. It may even look like a milkshake.
  3. #3 Re: Please help me save my GP!!!
    Jersey
    Thanks..I'll do that in the am if the weather permits..Can you give me a couple senerios of what to expect??
  4. #4 Re: Please help me save my GP!!!
    Most likely failure is the intake gaskets are gone and the EGR stove pipe could have finally melted through the upper intake and flooded the motor with coolant.
    Worst case is a head gasket but you'd likely have seen it smoking pretty bad just prior to complete failure.
  5. #5 Re: Please help me save my GP!!!
    Jersey
    Nope no smoke at all..Damn. I had the chance to fix something a year ago I didn't do it. I was nervous. I'm a diy type of guy. I have never taken this car to mechanic for the 7 years I've purchased it. I can't give up on her. 😊
  6. #6 Re: Please help me save my GP!!!
  7. #7 Re: Please help me save my GP!!!
    if the lower manifold where you got them rags stuffed in was soaking wet. you need to fix the egr stove pipe in the upper black plastic manifold, or replace it.
    as long as your this deep you should change the lim gaskets too. they came with plastic crap and they new metal gasket is much better.
    some reading for ya http://www.grandprixforums.net/threa...36-UIM-Failure
    seal them two little holes off and it cant leak coolant like that ever again on you. http://www.grandprixforums.net/threa...w-to-Mod-a-LIM
    if you hydro locked it lets hope you didnt keep trying to crank it, that can kill a rod bearing for ya.
    if you get any or already have coolant in the oil, dump a qt down the valley to wash the coolant out, then drain it and change the oil filter after your done with the gaskets, run it for a few minutes, then change the oil and filter again.
  8. #8 Re: Please help me save my GP!!!
    Jersey
    Small update: Its been very cold in Jersey so I'm taking my time with everything. I've drained the oil yesterday...Doesn't look milky to me at all. I also took the spark plugs out as well. Cylinder #6 had some coolant pressure as I took the plug out. Since the car has been sitting for a week now the oil filter is stuck to the point that the oil filter wrench is crushing it 😲😨. I'm going to try to manually turn the engine over with a socket before doing anything else. Had to replace vaacum line on Schrader valve as well.
  9. #9 Re: Please help me save my GP!!!
    if you put your filter wrench all the way to the top of the filter, right under housing, that is the strongest part, well the only part that wont crush on you. so grab it up top there. make sure your turning it the right way too.
  10. #10 Re: Please help me save my GP!!!
    GTX Level Member cheatah faheatah's Avatar
    May 2016
    Rouge Island
    Lefty, loosey. righty, tightey. Filter is upside down though, so clockwise as you look at it through the wheel well. Pull towards you on the right side of filter.
    For the record : I am NOT a naked meth-head who shoves rocks up my butt.
  11. #11 Re: Please help me save my GP!!!
    loose would be pulled to the firewall. tight to the bumper. only way to grab it with a wrench is via the wheel well. at least on my car thats how i get to it.
  12. #12 Re: Please help me save my GP!!!
    Buffalo
    Or stab it with a big screw driver and use it for leverage. Beast mode
  13. #13 Re: Please help me save my GP!!!
    SE Level Member 01Blackgtp's Avatar
    May 2014
    Colorado
    Quote Originally Posted by CrazyGuy03 View Post
    This!
    Only after you crush the **** out of it with the filter wrench and it still doesn't budge
  14. #14 Re: Please help me save my GP!!!
    GTP Level Member
    Oct 2014
    3 inch channel locks also works after crushing it.
  15. #15 Re: Please help me save my GP!!!
    So my guess was right??
    The EGR stove pipe melted the intake and put coolant in the motor?
  16. #16 Re: Please help me save my GP!!!
    Jersey
    I meant to say egr tube lol
  17. #17 Re: Please help me save my GP!!!
    where in NJ are ya? i got at least one egr stand with both tubes sitting around here.
  18. #18 Re: Please help me save my GP!!!
    Jersey
    I'm in Elizabeth..Hopefully tomorrow I can get things running.
  19. #19 Re: Please help me save my GP!!!
    your rather close, im in hackensack. if you wanted i could tune the egr out and you can just toss it in the trash. install two block off plates.
  20. #20 Re: Please help me save my GP!!!
    Jersey
    I appreciate your offer Scotty..I'm just praying that this snow doesn't ruin my Tuesday
  1. should i start to save up?
    By STEVEGTX in forum General Grand Prix Discussion
    Last Post: 01-12-2013, 07:39 PM
  2. save your pennys for this
    By redlinepontiac in forum Off Topic Discussion
    Last Post: 08-16-2011, 12:00 AM
  3. 98 GT to save a 99 monte?
    By william rhea 98GT in forum Introductions/Noob Questions
    Last Post: 06-13-2011, 09:52 PM
  4. Help me save my GTP!
    By Panzer4 in forum Off Topic Discussion
    Last Post: 05-24-2009, 03:56 AM
  5. Save the Sea Kittens!
    By Warhellride in forum Off Topic Discussion
    Last Post: 01-24-2009, 05:03 PM
