you need to swap the l67 flex plate or the the tc wont bolt up right. bolt pattern is not the same. the fuel lines wont reach right, but can be dealt with. evap is on the front, vs the rear of the gtp, so longer pig tail (cut and splice more wire) or move the evap. the map sensor, you need a l36 pig tail swapped in place of the gtp's.
other then those things its a direct swap.
