Thread: Coolant leak from the Timing cover.
Results 1 to 4 of 4
  1. #1 Coolant leak from the Timing cover.
    Sep 2012
    Ohio
    I basically have two questions, can I replace the timing cover without lifting the engine? If I don't have to lift the engine, what all has to come off?
    I hate the thought of it but would it be worth it to try some of that bars stop leak stuff? I've heard of it working miracles...
    coolant elbows and water pump have both been replaced in the past year.
    06 grand prix. 165k
  2. #2 Re: Coolant leak from the Timing cover.
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    You don't need to lift the engine, and stop leak is a bad idea. There's another member doing just that in another thread, http://www.grandprixforums.net/threa...Bad-water-pump
    His is a gtp, but you don't have to remove the intake to do yours.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: Coolant leak from the Timing cover.
    follow that thread war posted. its the same job. all directions are in there,
  4. #4 Re: Coolant leak from the Timing cover.
    Depending on your year.. check that when you did the coolant elbow etc.. that you didn't crack the timing cover where the lower elbow goes into it.
  1. Coolant leak from Timing Chain Cover??
    By wb22rules in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-01-2017, 04:06 PM
  2. Timing Cover
    By xcwilli11 in forum Wanted To Buy - Parts
    Last Post: 01-23-2016, 10:55 PM
  3. Oil leak from lower timing cover bolt hole
    By tweeder in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-04-2013, 11:11 PM
  4. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  5. Timing Chain cover
    By brichter45 in forum 3.1L V6 (LHO/LG8)
    Last Post: 01-08-2013, 12:11 PM
