Thread: Serpentine belt flies off and oil is sprayed on passenger side of engine compartment
Results 1 to 4 of 4
  1. #1 Serpentine belt flies off and oil is sprayed on passenger side of engine compartment
    Hamilton, Ontario
    Hello All,Driving on hiway, weather is great. All of a sudden, steering stiff then charging system failure. Check under hood and serpentine belt has come off. Check water pump pully and it wobbles when turned. Figure the water pump is bad. But where did the OIL come from. Check everything but can't see where it would be coming from. There was NO oil leaks on that side of the engine even after it has sat for a week. Any ideas as to where to OIL came from?
  2. #2 Re: Serpentine belt flies off and oil is sprayed on passenger side of engine compartm
    sure its not coolant? its pretty slick feeling.
  3. #3 Re: Serpentine belt flies off and oil is sprayed on passenger side of engine compartm
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    Coolant will turn black when it's all over the belt.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  4. #4 Re: Serpentine belt flies off and oil is sprayed on passenger side of engine compartm
    Hamilton, Ontario
    Thanks for your help. It is coolant. It was all dried up by the time I was getting to fix it. All good. Thanks again.
  1. Antifreeze on the passenger side of the engine block
    By nasa in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-25-2014, 10:16 AM
  2. Replaced serpentine belt, engine still chirping
    By ayoh482 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-12-2013, 12:46 PM
  3. A/C Leaking into passenger compartment?
    By Korben in forum General Tech Discussion
    Last Post: 06-23-2012, 06:45 AM
