Thread: junkyard tips
Results 1 to 10 of 10
  1. #1 junkyard tips
    GT Level Member uNda6gT's Avatar
    Jan 2009
    Baltimore
    im heading 2 the junkyard soon to grab a couple of cores,i need a m90 blower and a lower intake manifold (i believe) for the zzp ssm90 kit. 2 questions,how hard is it 2 get these parts off and exactly what tools do i need?
    02 Pontiac Grand Prix GT:Intake,SLP Powerflo Catback,HV3,DHP PCM, 15.3 @89mph
    96 z28 Geared Stalled Bolt On......Typical
  2. #2 Re: junkyard tips
    TDCRacing
    Guest
    You know i wish i could be more help. I know you will need a 15mm wrench for the tensioner for the belt (if it still has one)
    I think the S/C bolt heads are actually allen heads. It's been so long since i have messed with stock ones since I have pretty much always been intercooled and needed the longer one's i'm not even sure if there different.
    You'll need a flat head screw driver to take the clamp off for the air box.And I think the TB bolts are 10mm and you would need a socket for those.
  3. #3 Re: junkyard tips
    Charles City, IA
    I believe all the supercharger bolts are 10mm or 3/8. I think the LIM bolts are the same. TDC is right with the screw driver and 15mm. You will also need a 14mm I believe for the alternator bracket. I would just bring a set of sockets 10mm to 15mm deep and shallow. It would also be a good idea to bring an assortment of extensions and a u-joint.
    SMGPFC Two Nipple General
  4. #4 Re: junkyard tips
    Donating Users chrisb's Avatar
    Bucyrus, OH
    take a metric socket set up to 15mm and down to 8 and that should cover it ok, screw driver or two and that should be it.
    99 Grand Prix old build- CAI, Custom exhaust, HV3, Stage 2 TB, custom tune, ported heads intense s1x cam, headers.
    Nothing great Just a small T66 Turbo with a Hv3 On a stock tranny untill i finish the other one.
  5. #5 Re: junkyard tips
    GT Level Member GtpKo's Avatar
    Best place on Earth
    I just pulled an m90 off at the junkyard yesterday, theres a tricky bolt that has an extra nut on top if it by the throttle body. just remove all the 10mm things u can find if its a junkyard car anyway. Oh and *gently* pry the charger off u dont wanna crack it. If you give them a damaged core, they might not take it.
    Last edited by GtpKo; 10-05-2010 at 07:14 AM. Reason: yes i know this was feb 09, but helps searches ;)
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  6. #6 Re: junkyard tips
    Charles City, IA
    I hope he made it back by know a year and a half later.
  7. #7 Re: junkyard tips
    Not sure which part is funnier... the post date or the "tricky" bolt.
  8. #8 Re: junkyard tips
    Pennsylvania
    Some of the bolts are acrobatic, and you occasionally run across ones that can juggle.
  9. #9 Re: junkyard tips
    I love how on the l36 UIM it says "HIDDEN BOLT" and theres an arrow to nothing.... but none of them are hidden....
    Unless you count the two in the LIM that are generally covered in oil.... but then why doesnt the M90 say that on it?
    WHY DO YOU TAUNT US?!!@#
    And for anyone who actually dares to respond, i know they're on the outside....
  10. #10 Re: junkyard tips
    Best place on Earth
    Haha yea, I noticed the post date right after I posted.. Too much coffee makes me click-happy
    Still provides searchable material i soppose
  1. i want new tips!
    By QwikGT in forum Visual/Body Modifications
    Last Post: 04-18-2012, 01:19 AM
  2. Junkyard Supercharger
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-28-2009, 02:39 PM
  3. aftermarket spoiler at junkyard...
    By fst in forum Off Topic Discussion
    Last Post: 03-03-2008, 09:31 PM
  4. Need tips
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 11:55 AM
