Thread: junkyard tips
Results 1 to 10 of 10
Threaded View
  1. #5 Re: junkyard tips
    GT Level Member GtpKo's Avatar
    Best place on Earth
    I just pulled an m90 off at the junkyard yesterday, theres a tricky bolt that has an extra nut on top if it by the throttle body. just remove all the 10mm things u can find if its a junkyard car anyway. Oh and *gently* pry the charger off u dont wanna crack it. If you give them a damaged core, they might not take it.
    Last edited by GtpKo; 10-05-2010 at 07:14 AM. Reason: yes i know this was feb 09, but helps searches ;)
    2002 GT F23 5-speed swapped, SPEC stage 2+ clutch, ZZP Power Logs, E-brake handle swap.
  1. i want new tips!
    By QwikGT in forum Visual/Body Modifications
    Last Post: 04-18-2012, 01:19 AM
  2. Junkyard Supercharger
    By gpgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-28-2009, 02:39 PM
  3. aftermarket spoiler at junkyard...
    By fst in forum Off Topic Discussion
    Last Post: 03-03-2008, 09:31 PM
  4. Need tips
    By MTXGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-19-2008, 11:55 AM
