Thread: Attempting an Engine Swap: 05 (base) to 98 (GT) - both 3.8L V6 OHV 12V
Results 1 to 16 of 16
  1. #1 Re: Attempting an Engine Swap: 05 (base) to 98 (GT) - both 3.8L V6 OHV 12V
    SE Level Member Billycar11's Avatar
    Apr 2015
    Pa
    its not going to be a drop in install and you cant just swap engine you need the transmission too they are different generations plus who knows how you will get all the gauges to work swapping a new engine in to an old car it might be easier to fix the leak or get the damage repaired if possible
  2. #2 Re: Attempting an Engine Swap: 05 (base) to 98 (GT) - both 3.8L V6 OHV 12V
    Jun 2016
    Hillsboro, OR
    Quote Originally Posted by Billycar11 View Post
    Are you saying that the two aren't compatible and that I would need some sort of aftermarket parts and such? I was hoping that is was an easy drop 'n' install.
    Thanks!
    so your want the 05 engine in the 98 car right?
    all you really have to do is use the upper intake its tb and its sensors off off the 98 's engine, and compare all engine sensors plugs, swap sensors if need be, most should plug right in tho.
    you cant use the 05 tranny. its electronics are not the same. and the cable shiftier is not the same either.
    Yes, the 05 Series III engine is going to replace 98 Series II engine (if it's possible).
    So, is that considered a top swap, only using the upper intake and sensors? Still quite new to the car scene.
    Both trannys are fine, so that doesn't matter then.
    Thanks!
    Quote Originally Posted by Swiggles View Post
    Honestly the 98 motor is probably fine, might be a little hydrolocked but that can be taken care of. The lim (lower intake manifold) gasket went on but the head gaskets should be fine. Lim job is pretty easy, there's a how to video in the how to section.
    How bad is the 05? Can find parts cheap enough of its not that bad.
    So you're saying that I could just fix the 98 motor instead of replacing it? Along with replacing the LIM gasket?
    The 05 was totaled; it has a bunch of frame damage.
    Thanks!
  1. 2005 Base engine belt/pulley issue + other issues. Need insight
    By Taprot in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2016, 01:41 PM
  2. 2007 GP Base Engine Torque Mount Bracket Passenger Side
    By eetchickn in forum Wanted To Buy - Parts
    Last Post: 09-04-2013, 05:27 PM
  3. check engine light on 06 base GP
    By MrTube in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-23-2011, 06:58 PM
  4. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
  5. Attempting '97 Dual Climate Control Swap- Building shopping list
    By JBONE in forum General Tech Discussion
    Last Post: 09-17-2009, 11:20 AM
