Thread: check engine light on 06 base GP
Results 1 to 8 of 8
  1. #1 check engine light on 06 base GP
    New Jersey
    Today when I started my car to drive home from work I noticed the check engine light was on steady. I got out and checked the gas cap which did nothing.
    Car has just over 35K miles on it and has been used mainly for highway travel (100 miles a day) for the past 2 months.
    Is there anything simple this could be or should I start getting heartburn?
    Air filter is clean and I also put fresh gas in it.
  2. #2 Re: check engine light on 06 base GP
    St. Cloud, MN
    Get it scanned.
  3. #3 Re: check engine light on 06 base GP
    Omaha, NE
    Have the code read before you do anything else. Without knowing what the CEL is on for, we can't help you much.
    Autozone will usually scan your codes for you free of charge.
  4. #4 Re: check engine light on 06 base GP
    New Jersey
    I'll try to stop by one tomorrow. Thanks for your help!
  5. #5 Re: check engine light on 06 base GP
    New Jersey
    Autozone gave me the code P0411 which seems to indicate a problem with the air pump.
    Though this puts my mind at ease because I could care less about the air pump until I have to go back to inspection in a year, I assume the air pump should be covered under the extended emissions warranty?
  6. #6 Re: check engine light on 06 base GP
    free work is always worth a trip to the dealer in my book
  7. #7 Re: check engine light on 06 base GP
    Or rip it out...emissions are dumb
  8. #8 Re: check engine light on 06 base GP
    New Jersey
    Or no.
  1. Check Engine Light
    By klj5022 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-01-2011, 06:07 PM
  2. Check engine light on
    By CMURDAx in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-06-2010, 10:11 PM
  3. check engine light
    By kiljoy06 in forum General Tech Discussion
    Last Post: 01-11-2009, 07:27 AM
  4. Check Engine Light
    By WHITE02GTP in forum General Tech Discussion
    Last Post: 10-08-2008, 10:31 PM
  5. Check Engine Light
    Last Post: 09-01-2008, 09:01 PM
