Thread: Coolant leak driver side floor board?
Results 1 to 16 of 16
  1. #1 Coolant leak driver side floor board?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    My car is leaking coolant from the floor board on the driver side.what could be the problem?
    Sent from my SM-N910T using Tapatalk
  2. #2 Re: Coolant leak driver side floor board?
    leaking heater core.
  3. #3 Re: Coolant leak driver side floor board?
    Sep 2014
    New Orleans
    Oh ok but Yea it's leaking on the driver side and passenger side floor. So I have to fix the heater core?
  4. #4 Re: Coolant leak driver side floor board?
    Feb 2013
    37.295091, -121.930053
    its more common that the pass side shows it but yeah im with scotty FIX IT NOW or have low fluid forever
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  5. #5 Re: Coolant leak driver side floor board?
    you can by pass the heater core by looping one hose on the alt bracket. no heat but also no more leak.
    heater core is a real treat in these cars. (insert sarcasm font here) lol
  6. #6 Re: Coolant leak driver side floor board?
    Sep 2014
    New Orleans
    Scotty how to just block off my heater core
  7. #7 Re: Coolant leak driver side floor board?
    take both hoses off the fire wall. the one with a fatter end remove from the alt bracket, then take the other hose end and clamp it on the alt bracket, aka a loop is made literally.
  8. #8 Re: Coolant leak driver side floor board?
    Sep 2014
    New Orleans
    Guess what guys the top hose connecting to the firewall wasn't clamped on tight enough and that was probably causing my coolant to leak
  9. #9 Re: Coolant leak driver side floor board?
    only time will tell. the hoses can also get all worn out and no longer fit tight no matter how tight you clamp them. then can leak.
    one of mine did, it did fog the windshield but did not leak inside.
  10. #10 Re: Coolant leak driver side floor board?
    SWPA
    I'll burn my car before I would ever do the heater core again
  11. #11 Re: Coolant leak driver side floor board?
    Sep 2014
    New Orleans
    I tightened up the hose connecting to the firewall but it's still leaking coolant so should I just loop the hoses?
  12. #12 Re: Coolant leak driver side floor board?
    yup, bypass time, then buy a new heater core and have fun swapping it out.
  13. #13 Re: Coolant leak driver side floor board?
    GTP Level Member bonerjamz03's Avatar
    Apr 2009
    Upper Darby, PA
    If you do the heater core yourself, take the front seats out. I think there are 4 bolts to remove and it gives you much more room to work with.
  14. #14 Re: Coolant leak driver side floor board?
    St. Louis
    I'd rather do the heater core on my GP again then do ANY Ford heater core. At least with the GP I don't have to yank the entire dash off the firewall... IIRC I pulled the center console and pass. side seat out to get to the core in my GT.
    Here is a thread that may help--> http://www.grandprixforums.net/threa...re+replacement
  15. #15 Re: Coolant leak driver side floor board?
    Apr 2009
    Upper Darby, PA
    Quote Originally Posted by FordMan77 View Post
    My neighbor wanted me to replace the heater core on his Taurus when he saw me replacing the one on my GP. I looked up how to do it and couldn't tell him no fast enough lol.
  16. #16 Re: Coolant leak driver side floor board?
    SWPA
    Ah yes. I remember pulling the dash (twice) in my Mustang to do my heater core. The first time took a few hours. I had to do it again when the 1st replacement failed. The 2nd time was knocked out in under an hour.
  1. coolant leak drivers side behind engine (pic now)
    By RedneckGTP in forum General Tech Discussion
    Last Post: 10-07-2017, 07:58 AM
  2. Leaking Coolant from Front Driver side
    By mstrozier in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 11:15 AM
  3. 2004 GT2 Coolant Leak on Passenger Side
    By apok in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-22-2011, 10:14 PM
  4. Heavy Rain, water in driver side floor
    By msubully82 in forum General Tech Discussion
    Last Post: 09-08-2011, 11:51 PM
  5. coolant leak on passenger side under car.
    By Teardrop in forum General Tech Discussion
    Last Post: 09-07-2010, 03:42 AM
