Thread: Crack sound when I turn?
Page 1 of 3 123 LastLast
Results 1 to 20 of 43
  1. #1 Crack sound when I turn?
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    Hey I recently replaced my outer tie rod end on my front left wheel now I hear a cracking sound when I turn. Did I put the tie rod end on too close to the transmission or not close enough?
    Sent from my SM-N910T using Tapatalk
  2. #2 Re: Crack sound when I turn?
    Donating Users GoldGTP's Avatar
    Sacramento, CA
    Did you get an alignment?
    Might be a CV shaft...
  3. #3 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    Quote Originally Posted by GoldGTP View Post
    No I didn't get a alignment but I did install cv shafts on the driver and passenger side
  4. #4 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    My power steering pump Also have a leak I have to install that today also
  5. #5 Re: Crack sound when I turn?
    get an alignment. replace the other tie rod first tho, cause if one was bad the other is not far behind it.
  6. #6 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    Quote Originally Posted by ScottyDoggs View Post
    How much would a alignment cost me. I really don't like taking my car to a shop because labor cost be too high
  7. #7 Re: Crack sound when I turn?
    they are a flat rate fee. most shops are about $75. make sure they have a computer alignment rack and can do 4 wheel alignments.
  8. #8 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    Would they align my tire rods on both ends because I replaced both of them recently and align both of my cv shafts?
  9. #9 Re: Crack sound when I turn?
    they do the whole car no matter what. parts wear stuffs not in alignment any more.
    cv joints got nothing to with an alignment. unless you took the strut off the knuckle.
  10. #10 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    Ok I'll get a alignment today
  11. #11 Re: Crack sound when I turn?
    for real tho, change the other tie rod end, or you be spending 75 bucks again in a few months when it takes a crap also..parts like that you just change in pairs, unless you hit a curb and broke one or something like that.
  12. #12 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    I will
  13. #13 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    I went to get a alignment and the shop said I have to replace my struts and my passenger outer tie rod first and my passenger hub bearing
    Quote Originally Posted by Jason97GrandprixGT View Post
    I will
  14. #14 Re: Crack sound when I turn?
    well at least you have a honest shop. some would have just done the work and f-ed you up the ass.
    you may as well change the lca;s too. car will feel like someone elses when your done. aka so much better.
    theres cheap struts on ebay for like 220 shipped, all 4 struts. they say 10 year warranty. i was thinking about getting them when the time comes for my car.
  15. #15 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    What is lca's and I'll just go to the junk yard and look for good struts
  16. #16 Re: Crack sound when I turn?
    lower control arm.
    these things. they have your ball joint on the end, they go bad too. chances are your over due for them too. they run about a 100 for the pair shipped. dorman work fine. also get new sway bar end links if you do the lca's. most of the time you need to cut them off, the bolt rusts up solid. they are like 10 bucks.
    not a fan of junk yard struts, thats a real hit or miss deal.
  17. #17 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    lower control arm.
    I'm going to the junkyard to get 2
    Front hub bearings, and both struts. Ill buy the passenger outer tie rod new. But I just called auto zone to see how much would the front lca's would be and they told me 89 dollars each so I might just go to the junkyard to get that also
  18. #18 Re: Crack sound when I turn?
    sorry, buy stuff on line, way cheaper. rockauto is like 42 a side for the lca's local price is murder.
    the hub, but it at advance auto on line use a code, you get a good brand for under a 100 bucks with a 3 year warranty thats local. timkin skf and moog are the three to use. the rest are crap really.
  19. #19 Re: Crack sound when I turn?
    if you play with the discount codes you can do multiple orders breaking down the price to just over the min amount of money to make the largest discount code work.
    lca's one order, hub another, pick it up local 30 minutes later. retailmenot has codes.
  20. #20 Re: Crack sound when I turn?
    Sep 2014
    New Orleans
    Ok I can't wait for shipping because I do deliveries in my car for this restaurant so I have to do work on it on my off days but which parts do you think I should buy new I'll get the rest from the junkyard
  1. This is a crack, right?
    By hshift in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2013, 08:31 AM
  2. Lil Crack's day with dad
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 03-14-2012, 01:29 PM
  3. Poping sound when you turn
    By 05grndprix in forum Brakes/Suspension/Chassis
    Last Post: 05-04-2009, 04:29 PM
  4. weird sound when i turn the wheel...
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2008, 01:33 AM
  5. my car isnt making a WOSH! sound anymore when i turn it off?
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2008, 11:00 PM
