Thread: Crack sound when I turn?
Page 3 of 3 FirstFirst 123
Results 41 to 43 of 43
  1. #41 Re: Crack sound when I turn?
    those are called threads, and you cant judge anything by them. only count the threads and put your new stuff on to that count. but this is easier VVVVVVV
    when you take your old tie rod off, break the lock nut free, then put it back to the tie rod hand tight, then take the tie rod off, leave the lock nut in place and install the new tie rod to the old lock nut, make the nut tight, ( the inner rod spins, so it dont matter what angle its at when it hits the lock nut) thats as close as your gonna get it.
  2. #42 Re: Crack sound when I turn?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    the above method is about as close as you're gonna get. just make sure the actual tire rod end itself is the same length
  3. #43 Re: Crack sound when I turn?
    Enfield, CT
    I wouldn't worry about the thread count too much due to the fact that the alignment shop will correct it.
    Sent from my LG G3
  1. This is a crack, right?
    By hshift in forum Brakes/Suspension/Chassis
    Last Post: 01-15-2013, 08:31 AM
  2. Lil Crack's day with dad
    By LowRidinCrew in forum Off Topic Discussion
    Last Post: 03-14-2012, 01:29 PM
  3. Poping sound when you turn
    By 05grndprix in forum Brakes/Suspension/Chassis
    Last Post: 05-04-2009, 04:29 PM
  4. weird sound when i turn the wheel...
    By gtphayes in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-29-2008, 01:33 AM
  5. my car isnt making a WOSH! sound anymore when i turn it off?
    By 99prixgt in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-13-2008, 11:00 PM
