Thread: Car starts then rpm gauge drops immediately
Results 1 to 20 of 34
  1. #1 Car starts then rpm gauge drops immediately
    GT Level Member Jason97GrandprixGT's Avatar
    Sep 2014
    New Orleans
    I need help I replaced both 02 sensors, map, maf and iac sensor, also the fuel pump and filter. Now car won't stay on what did I do wrong
    Sent from my SM-N910T using Tapatalk
  2. #2 Re: Car starts then rpm gauge drops immediately
    St. Louis
    Do you still have pressure in the fuel rail after the car shuts down? Almost sounds like it's not feeding it fuel after the initial prime when you turn the key on.
  3. #3 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    Yea fuel is getting to it do you think it could be the Ignition control module
  4. #4 Re: Car starts then rpm gauge drops immediately
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Quote Originally Posted by Jason97GrandprixGT View Post
    Will it stay running at all? Or does it drop low and shoot back up?
  5. #5 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    Quote Originally Posted by SubwayBrat View Post
    No it start and dies right after start up
  6. #6 Re: Car starts then rpm gauge drops immediately
    Apr 2015
    Any Security light on? Have you tried holding the throttle and seeing if it will stay running if you give it gas?
  7. #7 Re: Car starts then rpm gauge drops immediately
    I'd even unplug the new maf sensor and see if it can run.
  8. #8 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    Thanks I unplugged the new maf sensor and it works so I guess my wire harness is damaged?
  9. #9 Re: Car starts then rpm gauge drops immediately
    Or the new maf is bad.
    Swap it for a new ac delco unit.
  10. #10 Re: Car starts then rpm gauge drops immediately
    St. Louis
    ^this^ The aftermarket MAF's for these cars can suck. I'd rather go to a JY and get a MAF than hassle with trying to get a new one to work out of the box from what I've seen. Or get a genuine Delco MAF as FFDP said.
  11. #11 Re: Car starts then rpm gauge drops immediately
    GT Level Member mguzzo's Avatar
    Buffalo NY
    why won't it run? Air, fuel, spark
    diagnose instead of throwing parts at it.
    fuel: you've replaced the filter and pump. Was it an OEM pump or aftermarket?
    Get under the car, disconnect the line from the pump into the filter. Put a container under the end of the hose.
    Key on without starting, listen for the pump to run and shut off. Did any fuel come out? if not your new pump is f*cked. I had two new airtex pumps crap out in one week because the check valve stuck closed and the system would not prime.
    OK so if fuel came out leave the line disconnected. Unscrew the filter. Go the the front of the engine and use an air line through the to purge the fuel lines from front to back. reconnect the filter and fuel line from the tank.
    Reprime a couple times, press the fuel needle valve and make sure gas comes out. Better yet use a pressure gage to check. You should have at least 50 psi at the rail and the pressure should not drop after prime.
    Find the diagram for bypassing the fuel pump resistor by bending the relay tab and do that.
    Next remove a spark plug then reconnect the wire from the coil. Crank the engine. If you have spark then your ICM and crank position sensor are good. If no spark you need to investigate further.
    "Silver Bullet" 98 GTP Coupe: Stock, rust free, and broadsided.
    Old '98 GTP Coupe: VS Cam, 3.0, S2IC, 42.5#, TOGs, N*/LQ4, Corsa. it once ran a 13 flat
    Older '98 GTP Sedan: Pullied, rockered, SSIC, etc. Stock 14.33 @ 96.5 / PB: 13.89 @ 101
  12. #12 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    Quote Originally Posted by mguzzo View Post
    It started running after I unplugged the maf connector so what could be the problem
  13. #13 Re: Car starts then rpm gauge drops immediately
    why did you change all those parts in the first place? theres more going on i bet.
  14. #14 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    Quote Originally Posted by ScottyDoggs View Post
    Because I thought the sensors went bad because the engine would die on me while I'm driving
  15. #15 Re: Car starts then rpm gauge drops immediately
    thats the crank sensor 99% of the time. the tach ever just quit working? then stall?
  16. #16 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    The rpm gauge would drop to 0 and the car would stop moving
  17. #17 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    I replaced the crankshaft position sensor before do you think that could cause the engine to die at idle?
  18. #18 Re: Car starts then rpm gauge drops immediately
    the harness to the crank sensor maybe bad. mine was. it ever set a code?
  19. #19 Re: Car starts then rpm gauge drops immediately
    Sep 2014
    New Orleans
    My check engine light never been on
  20. #20 Re: Car starts then rpm gauge drops immediately
    in that case id be checking the fuel pressure and the harness to the crank.
    all them parts you just changed mean nothing. with these obd2 cars you need a code to follow, or your guessing.
    a crank sensor will not throw a code most of the time, and neither will a bad fuel pump.
  1. car starts in cold then shuts off unless I immediately apply gas.
    By Greg84 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-03-2016, 06:13 PM
  2. rpm gauge drops to 0 while driving
    By Jason97GrandprixGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 03-29-2015, 07:00 AM
  3. RPM Gauge Drops to zero and Trac Off light turns on...
    By Treho54 in forum General Tech Discussion
    Last Post: 08-08-2012, 05:21 PM
  4. Starts and dies immediately
    By STS in forum General Tech Discussion
    Last Post: 02-13-2012, 03:23 AM
  5. 2001 Grand Prix GT starts then stalls then starts up and is fine???
    By 81X11 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-06-2012, 10:29 PM
