Thread: LeSabre 3800 Questions
Results 1 to 20 of 23
  1. #1 LeSabre 3800 Questions
    GTP Level Member Kaiser Pontiac's Avatar
    Jun 2015
    Land of 10,000 Salted Roads and Rusty Cars.
    So, my Dad is in need of a new beater work car, and a friend of ours' is selling his '98 Buick LeSabre for $500, it's a late model '97 (8th month to be exact). He's owned it for two years but never drove it, and he bought it from the original owner/buyer who religiously had it shop-serviced every 3k miles. It has 206k miles on it (commuter car), barely any rust, and overall nice condition. I know that buying a S/C '97 3800 and tranny is something to generally avoid, but I'm wondering if there is anything about '97 NAs (engine and tranny) that I should be worried about/look for, maybe avoid '97s?
    It's definitely a '97 engine - alternator bracket, engine cover...
    06 LaCrosse 57-79k sold;99 4dr GTP 134-138k sold;98 2dr GTP 183k parted;98 Regal 166-184k;04 GT2 204-206k sold;04 GTP 170-175k sold;09.5 G8 GT Sport 145k;09 G8 78-84k+;08 Prix 164k sold;06 Prix 168k sold;02 Regal 92k;09 G8 103k parted;04 GTP SpEd 139k parted;04 GTP 205k;'09 G8 105k parted;06 Prix 230k;04 CompG 138k
  2. #2 Re: LeSabre 3800 Questions
    Who is this guy? SubwayGuy's Avatar
    Apr 2015
    Just the normal 3800 common problems. Tranny is probably getting to the end of its life at that mileage.
  3. #3 Re: LeSabre 3800 Questions
    Kemmerer, Wyoming
    I think it has the 4T60, probably not something I would want, but for 500 it might be ok
  4. #4 Re: LeSabre 3800 Questions
    Jun 2015
    Yeah, I figured it probably has the older tranny - but, if it was well-maintained and never abused it might go for a while. I got a tranny out of a 12/97 GTP with 180k on it, that wouldn't work would it because the GTP trannies are different?
  5. #5 Re: LeSabre 3800 Questions
    Apr 2015
    Quote Originally Posted by Kaiser Pontiac View Post
    You can install a GTP tranny in a GT of the same year. I don't know if you can do it with that tranny though.
  6. #6 Re: LeSabre 3800 Questions
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Quote Originally Posted by SubwayGirl View Post
    not exactly, gear ratio's are different and would need a tune.
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  7. #7 Re: LeSabre 3800 Questions
    Apr 2015
    Quote Originally Posted by Grimsin View Post
    It will bolt up the same and you could basically swap trans. The GTP tranny he was will bottom line not work in this LeSabre.
  8. #8 Re: LeSabre 3800 Questions
    Yes it will, you just have to retune the pcm for the gear ratio change.
  9. #9 Re: LeSabre 3800 Questions
    Kemmerer, Wyoming
    the transmissions are totally different
  10. #10 Re: LeSabre 3800 Questions
    Jun 2015
    Okay, that's what I thought.
    Thanks for the input guys! Looks like we'll be going for it, should be exciting, hah.
  11. #11 Re: LeSabre 3800 Questions
    Kemmerer, Wyoming
    I would for that price
  12. #12 Re: LeSabre 3800 Questions
    If it is a 98 it should have a 4T65-E. And just FYI the engines were the same 97-98 they didnt change the alt bracket till 99.
    Also a 97 GTP engine and trans are not the things you want to avoid its the 97 car itself and the 97 na cars with the 4t60.
    The 97 l67 is 99% identical to the 98-03 with the exception being the vac tree on the blower and some of the sensors, and the tb change in 99. The 97-98 4T65-E HD has cooler lines for the tranny that screw in, the 99+ have quick release fittings.
  13. #13 Re: LeSabre 3800 Questions
    Jun 2015
    Quote Originally Posted by Slick2500 View Post
    Now to tell if it does in fact have a 4T65-E in it is very simple, look for 2 things,
    1. Is there a vac line going to the trans?
    2. Does the trans have just a wiring harness plugged into it.
    If it has a vac line its a 4T60-E
    If it has just a wire harness its a 4T65-E
    Ahhhh, thanks for the good info, guys! I'll have to check it out tomorrow...
  14. #14 Re: LeSabre 3800 Questions
    St Thomas Ontario
    Never said it wouldn't. But it won't be a install and drive away. Needs a tune
    Told ya
    I can never win.
    You'll get there lol.
  15. #15 Re: LeSabre 3800 Questions
    FWIW..
    A 96-99 H body is very different than W body. For example that Alt/bracket will be there until 2000. They were not changed and that's a better alt than any W body ever had.
    Trans.. being a 97, it'll have a 4T60. Swapped to a 65 would be as easy as adding 5 wires/pins and changing the transmission connector, blocking off a vacuum line and then updating the pcm from a 60 to a 65 which you need a dhp to do in my experience. I can tell you how to do it if you'd like. If you'd like to swap to a 99 harness, I can provide you with the pinout differences if you'd like.
    Just like the steer wheel controls.. you guys are suggesting normal W body stuff for a different vehicle. It's not apples to apples.
  16. #16 Re: LeSabre 3800 Questions
    FWIW..
    Yes Bill but its not a 97 its a 98. August of 97 would make it a 98 model year car. And unless Kaiser goes out and actually looks at the trans to see if it is in fact a 60 or 65 then we are all just sitting here wasting our time typing things.
  17. #17 Re: LeSabre 3800 Questions
    Jun 2015
    This is why I love this place, so much information!
    Is it worth it, what are the advantages? Also, only a DHP tuner would work? I've been hoping to find a used tuner and learn how to use it, is there any advantage for DHP vs. HPTuners?
    Thanks Bill!
  18. #18 Re: LeSabre 3800 Questions
    Jun 2015
    As soon as my Dad gets home from work tonight I'm gonna go check it out.
  19. #19 Re: LeSabre 3800 Questions
    Jun 2015
    It just has a wire harness plugged into it, so it's a 4T65-E.
  20. #20 Re: LeSabre 3800 Questions
    I still haven't read the first post..but congrats..
  1. 1997 Lesabre Annoyances
    By Impala131 in forum Other Vehicles
    Last Post: 11-21-2015, 12:02 PM
  2. 4T65E from LeSabre into GP
    By kc199 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-29-2011, 10:20 AM
  3. 97 LeSabre L36 locked up, not hydrolock
    By cdude20 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-08-2010, 04:32 AM
  4. 92 buick Lesabre
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-02-2009, 05:15 PM
