The bottom of the thermostat housing is slotted so the bolt only needs loosened.
What a pain! If you change one of these,just suck it up and remove the mass air flow and throttle assembly. That makes it much easier ti get the housing off. I suspect this design came from an engineer that is related to the creator of the side post battery.
