AJ1G
Not convinced that you can expect normal performance with NO exhaust system downstream of the exhaust manifold. Where will the fuel trims go with the O2 sensors hanging in ambient air? I just came though my problem , it was in fact a partially clogged cat. Car was running as bad as you described yours does. Mine runs like a raped ape now! The odd thing about my case was that I never did get any cat converter codes like the typical P0420 low cat efficiency code, as things got really bad I was on occasion tripping the P0404 EGR performance error code , which from what I have read, is commonly tripped by excessive backpressure from a clogged cat which causes the EGR valve to pop out of the shut position. Another symptom I had was rich exhaust smell getting into the car from the ventilation blower sucking in fumes from the engine bay that were pissing past the exhaust manifold seals on the head exhaust ports due to the excessive backpressure.
You said you were seeing 3 psi of exhaust backpressure. Was that measured at the upstream O2 sensor exhaust port? At normal idle, or a high speed idle? Seems pretty high, shouldn't see any significant pressure at that point at normal low idle. What do your fuel trims look like with the cat installed under load going up a long upgrade? If the cat is clogged you will likely see a bias toward lean (negative number) trim due to a rich mixture. If you are fuel starved ( like if your fuel pump is on its way out) , you would be seeing a bias toward rich trim. I'm mentioning that because my fuel pump actually just died the other day, but I dont think it was related to the clogged cat condition. That said, even with my 3.1's lousy performance with the partially clogged cat, the lean trim bias I was seeing under load was not that gross. But it was there. Another thing I was seeing from the clogged cat was a lot of coolant temp rise under load during uphill pulls, never had that under normal operation and that is now gone with the new cat.
Clogged cats on these cars we enough of a problem that GM extended the warranty on the cats for clogging to 120k miles/10 years. Mine only had 95K but was 13 years old so I was SOL for a warranty replacement from GM. The Walker cat my mechanic put on was about 250 bucks over the counter and I have seem them for about 180 at the usual Internet parts outlets.
