Hi there. New to the forums. I'll try to make this post as succinct as possible.
Symptom: Car doesn't start. She rolls over just fine, but it won't start, not getting spark. Last week, during the pretty extreme cold temperatures we had here in Michigan, my battery finally went kaput.
Swapped it with a newer one (not brand new, my dad had one in a parts car he just bought)
I've tested :
Voltage to the Ignition Control Module = Good
Ground to the Ignition Control Module = Good
AC Amp from the Crank Position Sensor = Good
Voltage from the Cam Position Sensor, while hand cranking the engine = Good.
I swapped out the Ignition Control Module for one I got from a buddy at work. He pulled it off a 91 Cutlass Supreme, and it's the same part number. Still no spark. (Not 100% guaranteed that the new(er) Module is good, but it was running when he pulled it off)
Still not getting any spark. If I'm testing it correctly, I don't think I'm getting power from the ECM to the ICM. I tested it by disconnecting the plastic connector, and placing the probes in the B+ wire and the Ground wire of the connector. And I got /negative/ voltage. Does that mean the ECM is bad, that I tested used the wrong wires, or am I just throwing a big ball of stupid at it?
Thanks in advance for any advice/troubleshooting tips. This thing has been driving my crazy.
