Also, how do the plugs on your 2 lower compression cylinders look? I recently had coolant seeping into the front left cylinder "the one next to the water pump" check to see if the plugs look steam cleaned opposed to the others, although this is unlikely like mentioned before your compression probably wouldn't be that high....
