ok so is there a possibility of the problem being the Coolant temp sensor. Because I thought that if that was bad then it would throw a code and the SES light would come on. But there is no SES light telling me this, so i just dont want to go out and buy a 20$ sensor when that is not the problem. Also the temp gauge in the dash seems to be workin right because i can tell the thermostat opens at about 195 like its suppose to so if the coolant temp sensor was bad woulding it be causing a different reading in the dash to since they run off the same resistor
