Hey the factory thermostat is set to open at 195F so this car should run fine with that thermostat in, i will bleed the system and see if that helps, so there is no thermostatic switch?? the fans come on and then turn off at like 200F so they stay on pretty long. i was gonna just run a switch to the fans to turn them on manually but one fan runs of 8Volts and the other fan runs off 6 volts, so ill have to get two variable resistors because ill be using power from the battery. this just seems like i am not fixing the original problem tho. So tell me this... what switch or sensor tells the fans that the temperature is 235F and to start running????
