Thread: Car stalls when warm at low/no speed but NOT in park or neutral...idle seems fine.
Results 1 to 8 of 8
  1. #1 Re: Car stalls when warm at low/no speed but NOT in park or neutral...idle seems fine
    Feb 2009
    Aberdeen, SD
    i had a 91 beretta w/ 3.1 that had a similar problem. i had the same symptoms once on a trip home. when i came to stops i stayed on the gas and used more brakes. i parked it to work on it the next day. when i went to work on it it ran fine. so i drove it. i parked it for about 10 mins (like yours) and it did the same thing again. this time it started running real bad on the trip home. it was missing on most of the cylinders shooting flames out the pipes and everything. i live 30 miles from nowhere so i just stayed on it hard all the way home. i checked coils and all that was fine except the timing was off (way off). so i had to replace the timing chain. along with that i replaced the cps. that fixed the timing issuses that i probably caused. it ran fine for a couple of days and started acting up again. a friend of mine who had a few of these motors told me to check my injectors. sure enough 2 of them had gone out. put in new injectors and it ran like a charm. hopefully something in this long story can help you out. good luck
  2. #2 Re: Car stalls when warm at low/no speed but NOT in park or neutral...idle seems fine
    Jul 2010
    Northwest Ohio
    Hello,
    Just wondering if you found an answer to your problem. I have 96 grand prix 3.1L that does something similar. Runs fine when cool. But when it gets to full hot if it cools down for 20-30 min it will stall after putting it in drive. It spits and sputters, obviously misfiring, in fact the the code reader lists it as a general misfire sometimes. But once it stalls it won't start up again at all until it is completely cooled. Then it fires up just fine. I've tuned it up. Replaced the ignition control module and the coil packs but no help. I'm stumped.
  1. Replies: 25
    Last Post: 09-01-2010, 05:49 AM
  2. Runs 5 minutes...Stalls...Changed everything
    By TAWinner23 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-09-2009, 02:47 PM
  3. 01 GTP. Car shakes when in Neutral and Park.
    By Freebeer187 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-13-2008, 03:00 AM
  4. Pontiacs in the Park-VA
    By mlambert in forum Shows and Events
    Last Post: 06-03-2008, 09:06 PM
  5. Rough when cold; smooth when warm...???
    By DanGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-11-2008, 07:34 PM
