Thread: Removing Exhaust Manifold
Results 1 to 5 of 5
  1. #1 Removing Exhaust Manifold
    Newport News VA
    Looking for opinions on if it will be easier to remove the exhaust manifold from the head, or the pipe from the exhaust manifold.
    I am trying to replace the head gaskets, and I am one step away from getting to the rear gasket (front head is already off). I am worried about breaking off bolts and being totally screwed. So, do you think it would be easier to remove the exhaust manifold, or the pipe that attaches to the exhaust manifold, so I can replace the head gasket?
    I know both will be rusted, and I have PB blaster ready to go.
    Thanks for your help.
  2. #2 Re: Removing Exhaust Manifold
  3. #3 Re: Removing Exhaust Manifold
    Newport News VA
    OK, I removed the six rear exhaust manifold nuts, but the head is not separating from the manifold. Do I just need to tap it gently to loosen up the seal, or have I missed a bolt somewhere?
  4. #4 Re: Removing Exhaust Manifold
    Try loosening up the from mounts...to let the engine rock forward and back...that should break her loose.
  5. #5 Re: Removing Exhaust Manifold
    SE Level Member brokenmercy's Avatar
    Jun 2010
    Ocala, FL
    What kind of car do you have?
    Some are harder than others. But usually, regardless, you have to remove the exhaust manifold.
  1. Hot exhaust manifold. New cat, still problems
    By cavGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-13-2010, 07:19 PM
  2. exhaust manifold ?
    By 04GTPCOMPG in forum General Tech Discussion
    Last Post: 11-09-2009, 03:20 PM
  3. Removing Manifold Heat Shield.
    By SuperSport in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-06-2009, 04:57 PM
  4. Exhaust Manifold bolts
    By Incomudrox in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-02-2008, 06:05 PM
