Thread: Removing Manifold Heat Shield.
Results 1 to 15 of 15
  1. #1 Removing Manifold Heat Shield.
    GTP Level Member SuperSport's Avatar
    Michigan
    Would it hurt anything to remove the front and rear exhaust manifold heat shield?
  2. #2 Re: Removing Manifold Heat Shield.
    Banned - Busted For Scamming
    Feb 2009
    its there for a reason, why would you want to remove it? to save 2 pounds maybe?
  3. #3 Re: Removing Manifold Heat Shield.
    Michigan
    To prevent oil buildup and possible fire. I am planning on canging my valve cover gaskets this weekend as well. Why are the shields there? Besides collecting oil sludge.
    2001 Grand Prix GT Coupe
    Comp G Wheels - SS Corners - Infinity Sound - Tint - Digital DIC Swap - 893 Fogs
  4. #4 Re: Removing Manifold Heat Shield.
    Dec 2008
    Canada
    Not even close to two pounds lol, just leave it on like he said. It is there for a reason.
  5. #5 Re: Removing Manifold Heat Shield.
    Michigan
    Ok. Ill make sure they are clean, then put them back on. Thanks.
  6. #6 Re: Removing Manifold Heat Shield.
    Feb 2009
    to keep heat off the spark plug wires and the engine bay. just clean them until you change your gaskets.
  7. #7 Re: Removing Manifold Heat Shield.
    You can also get some coated and ported manifolds...they are way cooler than stock temp. wise and flow a lot better...and you won't need the covers...I took mine off when I got my car but that was just me...
  8. #8 Re: Removing Manifold Heat Shield.
    Feb 2009
    you can ceramic coat anything as far as exhaust yourself and save money
  9. #9 Re: Removing Manifold Heat Shield.
    GT Level Member skidoojames151's Avatar
    seattle
    ceramic coating out of a spray can? If thats what you mean then thats not much better than hi temp paint...real ceramic coating has to be done with a special process
  10. #10 Re: Removing Manifold Heat Shield.
    Feb 2009
    Quote Originally Posted by skidoojames151 View Post
    Negative. They make a actual ceramic coating you have to use a spray gun for then bake it. Not spray paint.
  11. #11 Re: Removing Manifold Heat Shield.
    Jersey
    those heat shields are garbage, i tossed mine when i did my top swap, makes changing plugs that much easier. My ceramic coating on my plog burnt off and now has surface rust, waste of $$ imo
    16' wrx sti- stock
  12. #12 Re: Removing Manifold Heat Shield.
    Feb 2009
    Well they didnt do it properly or they didnt ceramic coat, just high temp painted it. A proper ceramic coating job will not burn off.
  13. #13 Re: Removing Manifold Heat Shield.
    Jersey
    oh definitely, any paint or coating job would be way better from a shop, i was just saying zzp didn't do such a great job
    16' wrx sti- stock
  14. #14 Re: Removing Manifold Heat Shield.
    Does ZZP ever do a good job except ship their crap out really fast?
  15. #15 Re: Removing Manifold Heat Shield.
    Jersey
    16' wrx sti- stock
  1. Replies: 2
    Last Post: 05-26-2009, 05:37 PM
  2. No heat -- or very little
    By Teancum in forum General Tech Discussion
    Last Post: 03-27-2009, 07:55 AM
  3. Cut off heat shield?
    By kamper98 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-03-2008, 10:03 PM
  4. Heat shield with Plog?
    By Deezul_AwT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-02-2008, 09:17 PM
  5. How to install throttlebody heat shield
    By ryangtp89 in forum General Tech Discussion
    Last Post: 05-03-2008, 11:34 AM
