Thread: Jacked transmission up? Tips sensor.
Results 1 to 5 of 5
  1. #1 Jacked transmission up? Tips sensor.
    Sep 2015
    Auburn
    I have a low Mile 99 gtp. I replaced a throttle position switch that was damaged when I dropped a ratchet on it. It was functional even though I broke the surround for the plug. I used a new oem part. Unfortunately I installed it wrong and the transmission wouldn't shift out of first gear until 4k.
    I drove it back home and pulled it out again and noticed I installed it incorrectly and didn't allow it to rest against the pins. After I put it back together I drove it around town and it drove and shifted fine. A little later that night I drove it again but the transmission is slipping. Like it isn't engaged in drive or half between neutral and drive. I put it in park and back into drive but it stayed the same.
    The car has never had transmission issues and nothing smells burned in the atf. Car showed no issues before I replaced the tps. I tried the old tips but it still does it.
    Anyone ever have anything like this come up?
  2. #2 Re: Jacked transmission up? Tips sensor.
    Does it move fine in 1st or 2nd??
  3. #3 Re: Jacked transmission up? Tips sensor.
    Sep 2015
    Auburn
    I didn't get into second. It revs and barely moves in 1st. It moves enough to get going but it is slipping.
  4. #4 Re: Jacked transmission up? Tips sensor.
    No, I mean throw the trans into manual first and second gear.
  5. #5 Re: Jacked transmission up? Tips sensor.
    He's diagnosing your forward band
  1. Transmission or Throttle Positioning Sensor?? Help!
    By kyliek23 in forum General Grand Prix Discussion
    Last Post: 07-02-2013, 08:49 AM
  2. Tips on getting the new transmission filter in?
    By foghelmut in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-13-2011, 10:41 AM
  3. New Taillights/Old Ones Jacked!!!!
    By nikkigpgt00 in forum Visual/Body Modifications
    Last Post: 04-11-2011, 04:05 PM
  4. Soo i jacked the car up today..
    Last Post: 12-02-2010, 08:14 PM
  5. jacked up radio....
    By shiguy in forum Audio, Security & Visual Electronics
    Last Post: 03-02-2010, 04:09 PM
