Thread: Trans cooler check ball conversion. From external to internal?
Results 1 to 7 of 7
BrandonHall10 Trans cooler check ball... 05-26-2015, 01:10 PM
BillBoost37 Re: Trans cooler check ball... 05-26-2015, 01:30 PM
BrandonHall10 Re: Trans cooler check ball... 05-26-2015, 01:41 PM
BillBoost37 Re: Trans cooler check ball... 05-26-2015, 02:03 PM
BrandonHall10 Re: Trans cooler check ball... 05-26-2015, 02:07 PM
Impala131 Re: Trans cooler check ball... 05-26-2015, 02:12 PM
BrandonHall10 Re: Trans cooler check ball... 05-26-2015, 02:23 PM
  1. #1 Trans cooler check ball conversion. From external to internal?
    Mar 2014
    Tucson
    1.) Is it possible to convert external check ball (inside cooler fitting) to internal check ball (in channel plate)?
    2.) If so, what parts would it take? Can I get JUST those parts?
    My reason for wanting to do so is for an easier cooler install. It would be nice to plumb directly into the transmission case with my AN fittings and omit the factory quick connect fittings. Much like the LS guys get to do.
    3.) Am I missing any disadvantages of an internal check? Why did GM go to an external check on the '00 to '03 4t65e's?
    Let's assume the transmission is already apart for rebuild.
  2. #2 Re: Trans cooler check ball conversion. From external to internal?
    Yes you can add the checkball inside. My last trans actually had both because I used a newer casing with a VB that had the internal.
    I am unsure on the benefit of the move. Unless they found it easier to replace in the fitting vs internal.
    All you'd need is the checkball and gaskets.
  3. #3 Re: Trans cooler check ball conversion. From external to internal?
    Mar 2014
    Tucson
    Thanks Bill.
    Are all the 4t65e channel plates the same? Let's say I find an '05 Impala (or some other w-body with an internally checked 4t65e) at the pick a part... Could I just take the entire CP from that?
    Maybe I'll shoot Dave an email to see if I can purchase the needed parts from TEP.
  4. #4 Re: Trans cooler check ball conversion. From external to internal?
    Not all channel and VB's are the same. I found out the long painful way.
  5. #5 Re: Trans cooler check ball conversion. From external to internal?
    Mar 2014
    Tucson
    Uh-Oh. Guess I need to do some Googling....
  6. #6 Re: Trans cooler check ball conversion. From external to internal?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Just out of curiosity, what are the ramifications of not running a check ball period?
    My 04 Impala LS has the check valve in the fitting, not sure about the 04 SS though.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  7. #7 Re: Trans cooler check ball conversion. From external to internal?
    Mar 2014
    Tucson
    The torque converter will drain.
  1. how to add a trans cooler
    By DirtDog in forum General Tech Discussion
    Last Post: 09-17-2012, 09:14 PM
  2. External Trans Cooler
    By ls1camino in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2012, 12:34 PM
  3. trans cooler and oil cooler
    By mhartwig in forum General Tech Discussion
    Last Post: 11-17-2010, 10:33 PM
  4. Internal Trans Parts that Are Questionable
    By JJ91284 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-19-2008, 12:36 AM
