'01 GTP. Correct me if I'm wrong: Final drive 2.93:1, 4th gear 0.7:1. Tires 225/60-R16, 26.6" diameter. Right?
Plugged those figures into the calculator here:
http://www.crawlpedia.com/rpm_gear_calculator.htm
If I calculate correctly, at 65mph in 4th gear with the lockup clutch engaged, shouldn't I be at around 1684 RPM? That seems low to me, but I'm used to driving cars with smaller engines that need to rev higher.
I can hear it shift into all four gears, but I'm cruising at about 2500 RPM at 60-62 mph, going easy on the accelerator. Is that normal? It's about what I would expect for a much smaller engine, but I'm surprised a 3.8L needs to rev that high just to cruise.
Highway MPG is 24 if I'm lucky, but usually lower.
Does it seem like I should be looking into the lockup clutch? Or a solenoid, or bad connection, or something? Or is this normal highway RPM, and I calculated wrong?
