Thread: ac compressotr not engaging
Results 1 to 8 of 8
  1. #1 ac compressotr not engaging
    SE Level Member runn141's Avatar
    Nov 2008
    ohio
    i have a 97 gran prix with a 3800 series 2 and the ac compressor will not engage. i assume it is the clutch and needs replaced because i put 134a in it and it still wont. is there any relays or switches i need to replace first? and if so where are they located?
  2. #2 Re: ac compressotr not engaging
    If it's cold out it won't engage.
  3. #3 Re: ac compressotr not engaging
    Nov 2008
    ohio
    it wont in triple digit temperature either
  4. #4 Re: ac compressotr not engaging
    How much R-134a did you put in it?
  5. #5 Re: ac compressotr not engaging
    Nov 2008
    ohio
    3 full cans and it wont take anymore
  6. #6 Re: ac compressotr not engaging
    You over filled it. That's worse than if it had to little in it.
  7. #7 Re: ac compressotr not engaging
    SE Level Member Buggsy's Avatar
    Eau Claire, WI
    What dsmuts said. Refigerant needs to be in spec. You could have a bad clutch, but it won't work under or over pressurized. I'm not really sure, but with that much in the system you may need to have it completely vacuumed out now.
  8. #8 Re: ac compressotr not engaging
    Dec 2012
    PA
    Please explain how you got 3 cans into the system if the compressor won't engage. More than likely the system has no pressure at all due to a massive leak and therefore the cans probably just expelled into the atmosphere. A sealed system will not take more than one can unless the compressor is running. You need to see how much pressure is actually in the system at this moment. It should be around 50 PSI when turned off, plus or minus maybe 10.
  1. AC Compressor Engaging at Inapproporiate Settings
    By kurthaver in forum General Grand Prix Discussion
    Last Post: 11-26-2012, 09:38 PM
  2. A/C Clutch Not Engaging
    By ShadowSwept in forum General Tech Discussion
    Last Post: 07-01-2012, 09:31 PM
  3. ABS engaging under normal braking SOMWETIMES
    By davidw in forum Brakes/Suspension/Chassis
    Last Post: 05-28-2012, 08:00 PM
  4. '08 ac clutch engaging/disengaging eraticly
    By tomekzet in forum Introductions/Noob Questions
    Last Post: 05-28-2012, 08:29 AM
  5. noticed my TC is not engaging?
    By fst in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-12-2009, 09:27 AM
