Thread: Trans slipping in first
Results 1 to 4 of 4
  1. #1 Trans slipping in first
    May 2014
    terre haute, Indiana
    My Trans just started slipping in first gear on take off. It will not move at all until I put it in manual mode then it'll go but slipping badly this is a 2007 gp gxp any ideas?
  2. #2 Re: Trans slipping in first
    its tranny time. aka rebuild time.
  3. #3 Re: Trans slipping in first
    Kemmerer, Wyoming
    the gxp transmissions wear out faster. gm really should have built them stronger for that engine.
  4. #4 Re: Trans slipping in first
    If you're at or over 100k miles, that's a good bet that you need a rebuild or swap in a semi built trans to handle the power and heat.
    I'd install a trans cooler after you get everything done to keep the temps down.
  1. Trans slipping bad
    By jrmac88 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-06-2013, 07:10 AM
  2. Trans Slipping
    By SVTf in forum 3.1L V6 (LHO/LG8)
    Last Post: 03-28-2013, 08:17 PM
  3. Trans Slipping - HELP!!
    By coolken84 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2011, 01:17 PM
  4. Trans slipping when cold
    By Xhondaguy in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-27-2011, 12:08 PM
  5. Auto trans. slipping.
    By srspicer in forum General Tech Discussion
    Last Post: 10-28-2009, 12:52 AM
