Thread: Trans slipping when cold
Results 1 to 3 of 3
  1. #1 Trans slipping when cold
    SE Level Member Xhondaguy's Avatar
    May 2008
    chicagoland
    Ive been having a problem over winter and this spring where my trans slips a little bit when its cold. It does it when i first start it up and drive but only if i go over like an eighth throttle. When it is warm it has no problem and works perfect, i have read that this could possibly be a clogged trans filter or some seals getting worn out and swelling when it finally gets warm to build up the line pressure. Just looking for some input from you guys to see if there is something i can easily do to fix it instead of buying a new trans
    3.4, 1.8RR, HAI, Intense tune, Ported M90, MSD wires, Autolite 104s, HID's, and a sparkle paint job
  2. #2 Re: Trans slipping when cold
    Being that you said it could be a clogged filter. My first suggestion is service the transmission with a filter and fluid pan drop service. Add a quart of lucas stop slip in when you do it and see if that doesn't sprinkle a little magic pixie dust on your trans.
  3. #3 Re: Trans slipping when cold
    SE Level Member kenizzle36's Avatar
    Apr 2011
    Menasha, Wisconsin
    Didnt know they made that stuff???? I might try that before I dive into trying to swap trannys.
    99 GP GT- Bosal mufflers, Custom intake.
  1. Trans Slipping - HELP!!
    By coolken84 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-01-2011, 01:17 PM
  2. trans slipping, sqeeling,and tcc locking?
    By xBlacKxGTPx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-30-2011, 01:19 AM
  3. Trans is dead on cold startup
    By brand121 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-21-2010, 03:45 PM
  4. Auto trans. slipping.
    By srspicer in forum General Tech Discussion
    Last Post: 10-28-2009, 12:52 AM
  5. Trans banging when going into reverse - cold only
    By markh in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-31-2008, 06:15 AM
