Thread: ZZP Trans Pan Gasket ?
Results 1 to 16 of 16
  1. #1 ZZP Trans Pan Gasket ?
    Jul 2012
    Chicago
    Got one of these suckers for real cheap, couldn't say no. Gonna appreciate the drain bolt.
    Can I reuse the factory gasket with this pan? I figured yes, but just want to ask to make sure.
    -Carl
  2. #2 Re: ZZP Trans Pan Gasket ?
    Dec 2010
    DMV
    Yup the stock one is metal so your fine
  3. #3 Re: ZZP Trans Pan Gasket ?
    Kemmerer, Wyoming
    I think they are reuseable, but they will end up leaking at some point. why not do the job right and put a new one on? on my last grand prix I was leaking transmission fluid and got lucky because all I did was tighten a couple bolts and it stopped leaking.
    you can probably get a transmission pan gasket a lot cheaper on amazon or rock auto than what zzp charges.
  4. #4 Re: ZZP Trans Pan Gasket ?
    Dec 2010
    DMV
    I've re used the stock trans pans gasket forever. Never had to replace it. Just check back after a few days and re check the bolts. They tend to loosen a bit after the weight from the fluid in the pan
  5. #5 Re: ZZP Trans Pan Gasket ?
    Arizona
    Fyi a new doorman pqn eith a drain plug is 30 bucks
  6. #6 Re: ZZP Trans Pan Gasket ?
    Jul 2012
    Chicago
    Thanks guys, my current gasket has been reused twice already. No leaks.
    Got this thing for 50 bucks, so i guess I'm not too upset about just now finding out that Dorman makes a replacement pan with a bolt. Hahaha
    Thanks for the advice guys.
  7. #7 Re: ZZP Trans Pan Gasket ?
    Arizona
    50 bucks niceeeeeee
  8. #8 Re: ZZP Trans Pan Gasket ?
    Jul 2012
    Chicago
    Call it a half Christmas, half luck, gift. lol
    -Carl
  9. #9 Re: ZZP Trans Pan Gasket ?
    the factory pan gasket is the best one you will ever own, clean/inspect and re use.
  10. #10 Re: ZZP Trans Pan Gasket ?
    hangover park IL
    if using it with the zzp alum pan with their horrible rail machining....rtv the gasket to the pan and leave the other side clean. the trans case is nice and smooth, two allum pans have leaked on me
    ~James~ Psychotic Gearhead
  11. #11 Re: ZZP Trans Pan Gasket ?
    GTP Level Member
    Oct 2014
    I reused the factory one for 322,000 miles,, probably 7 or 8 changes, never a leak.
    Sent from my iPad using Tapatalk
  12. #12 Re: ZZP Trans Pan Gasket ?
    I live here. DirtDog's Avatar
    Jun 2012
    The factory trans pan gasket is only 50 bucks from the dealer for a new one. Or 30ish for a new one on Amazon.
  13. #13 Re: ZZP Trans Pan Gasket ?
    Jul 2012
    Chicago
    Quote Originally Posted by Turbocharged400sbc View Post
    Thanks for the advice, definitely don't need any leaks.
    -Carl
  14. #14 Re: ZZP Trans Pan Gasket ?
    Aug 2013
    McDonald PA
    Quote Originally Posted by 91parkave View Post
    This. I'm not even putting the stock pan back on my next drop
  15. #15 Re: ZZP Trans Pan Gasket ?
    Jul 2012
    Chicago
    I'm excited to have a drain plug, it'll make removing the pan so much easier, particularly for my shrimpy self.
    -Carl
  16. #16 Re: ZZP Trans Pan Gasket ?
    GT Level Member April Thompson's Avatar
    Dec 2014
    Moline, IL
    Thanks for the advance warning; I was getting all googly-eyed at seeing an aluminium pan! Now I'll go with the Dorman one with the drain plug; also, thanks everyone for mentioning the reusable nature of the gasket!
    2004 Grand Prix GT2-clone A.K.A. the "Cybercar;" Galaxy Silver; 146K miles; RETROFITS: leather-wrapped steering wheel (w/audio controls) & shift knob; trip computer; map lights & dual lighted vanity visors; heated (?) leather seats w/ 10-way power driver's seat; ​HUD conversion
  1. Trans Side Cover Gasket--New or Re-Use?
    By Mr D in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-28-2013, 12:38 PM
  2. Trans pan gasket
    By vertebrate in forum General Tech Discussion
    Last Post: 09-05-2012, 05:36 AM
  3. Help is it head gasket water pump or intake gasket
    By jared71 in forum Introductions/Noob Questions
    Last Post: 02-14-2012, 01:26 PM
  4. 1997 2nd design 4T60E Trans pan gasket
    By Pauley in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 05-01-2011, 07:06 AM
