Thread: Is this normal?
Results 1 to 13 of 13
  1. #1 Is this normal?
    Oct 2011
    Puyallup WA
    New cv shaft new wheel bearing and new upper poly mounts...crazy loose sound and vibration when turning right really can make noise come out when I lock it in 1st gear and turn circles in parking lot...did this before new shaft and now its worse and starting to do it even when you are going straight
    08 G8 GT - exhaust Tune
  2. #2 Re: Is this normal?
    I think its supposed to have a little bit of back and forth movement but I don't think its supposed to have any up and down or side to side movement.
  3. #3 Re: Is this normal?
    Mar 2014
    Tucson
    That's about how much mine moves. Recently put CV shafts in both sides. Kept shoving on that side waiting for it to tighten up...
    Not saying it's right though. :shrug: Waiting to see what others say also.
  4. #4 Re: Is this normal?
    Oct 2011
    Puyallup WA
    Looking at it doesn't look its in the trans far enough but when I installed it it popped into place....at this point deff not ruling it out since my vibration is still very much around...the shaft has about the same amount of side to side and up and down movement when its sitting on the ground with the tire on...any chance the shaft they gave me is to short? Or is the trans taking a dump
  5. #5 Re: Is this normal?
    Oct 2011
    Puyallup WA
    Shaft has a half inch gap between the trans and shaft
  6. #6 Re: Is this normal?
    Dec 2012
    Where 4T65E's were born
    Tug on it. If it doesn't slide out of the trans, the clip is seated.
    Sold.
  7. #7 Re: Is this normal?
    Oct 2011
    Puyallup WA
    I can tug on it and it doesn't pull out...just has play up and down
  8. #8 Re: Is this normal?
    Dec 2012
    Well its in far enough then, Are you sure it's the cause of the noise?
    Sold.
  9. #9 Re: Is this normal?
    Oct 2011
    Puyallup WA
    Not sure of anything really...but noise and vibration is on the right side when turning right
  10. #10 Re: Is this normal?
    Oct 2011
    Puyallup WA
    If new lower motor mounts don't fix my vibration then I'm out of ideas and may pull the shaft
  11. #11 Re: Is this normal?
    Oct 2011
    Puyallup WA
    Anybody else have any thoughts on this or my issue?
  12. #12 Re: Is this normal?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Maybe it is a defective wheel hub? Kinda sounds like a wheel hub issue to me. Does the vibration increase/change with speed?
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  13. #13 Re: Is this normal?
    Oct 2011
    Puyallup WA
    Only does it when turning and accelerating...coasting turning doesn't do it
  1. is this normal mpg?
    By des19 in forum General Grand Prix Discussion
    Last Post: 07-16-2012, 02:47 PM
  2. Is this normal
    By Chad Gervais in forum General Grand Prix Discussion
    Last Post: 07-13-2012, 10:02 PM
  3. using oil normal?
    By benravingmad in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-13-2011, 03:38 AM
  4. Is this normal?
    By 2001GTP in forum General Tech Discussion
    Last Post: 01-11-2010, 08:10 AM
  5. Is this normal
    By TorqueAutoMotiv in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-18-2009, 11:19 PM
