Thread: radiator side transmission oil cooler connector part #?
Results 1 to 5 of 5
  1. #1 radiator side transmission oil cooler connector part #?
    GTP Level Member buickman104's Avatar
    NYC
    I need to buy a new radiator side trans cooler connector. Went to rock auto under "Oil Cooler Line Connector" there are a few options as fittings describes as "radiator side". Can anyone confirm the part numbers for the correct radiator fitting?
    ACDELCO Part # 52481097
    DORMAN Part # 800721
    ACDELCO Part # 19130039
    DORMAN Part # 800605
    Any help would be greatly appreciated.
    2000 Bronze Metallic GTP
    Power :Gen V, 3.6 pulley, 3 inch down pipe, Power log, FWI,and DHP Power Tuner,
    Handling: Vogtland Springs, GMPP sway bars, STBS, 18" Konig backbone, CTS-V Front brakes and GXP rear brakes
  2. #2 Re: radiator side transmission oil cooler connector part #?
    Apr 2009
    TN
    If the radiator end of the oil line is still good, you will try the ACDELCO Part # 19130039 only the OEM style connector replacement.
  3. #3 Re: radiator side transmission oil cooler connector part #?
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    I believe the Dorman "Help!" section in some auto parts stores has the connector you need. Bring in your old connector and you can match it up.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  4. #4 Re: radiator side transmission oil cooler connector part #?
    NYC
    The old connector was long lost. So nothing to compare. My car has been run with the radiator cooler bypassed and straight to the external. My trans can't get up to operating temp in the winter that is why I am trying to do this now. New lines have been ordered and are on their way, but the radiator just has the threads now, no old fittings to compare. I live in an apartment, have no access to a backyard or driveway. Have to make arrangements for those types of privileges (a place to work my car) and they come seldom. That is why I am in the dark and would like to know the part number for sure so there are no surprises.
  5. #5 Re: radiator side transmission oil cooler connector part #?
    Apr 2009
    TN
    According to the listing, they all gonna fit. They are just made of different materials and better design like ACDELCO Part # 52481097
  1. transmission cooler
    By bryanrhoads77 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-18-2014, 08:11 AM
  2. Trans cooler, Is there a high side and low side of radiator ?
    By JT2002GTP in forum General Tech Discussion
    Last Post: 03-28-2013, 03:05 PM
  3. Cooler line pops out at radiator. Dealership says I need a new radiator?!?! Pic
    By nickbuol in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-27-2013, 08:27 PM
  4. What to replace radiator trans cooler lines with barbed fittings. Which to buy?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2011, 11:10 AM
  5. Transmission Cooler Line leaking at radiator
    By Obrigado in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-01-2010, 04:36 PM
