Thread: Lost transmission? PLEASE HELP
Results 1 to 15 of 15
  1. #1 Lost transmission? PLEASE HELP
    SE Level Member sco77's Avatar
    MD
    So I just made a post a week ago about my transmission doing some RPM surging/jerking at highway cruise... Well tonight I come up to a stop light and then when it turned green I had no power, no gear worked, I had to push it off to the side of the road. After I let it sit off for 5 mins I started it up and was able to engage drive again and make it into a parking lot where it lost all gears again.. Once again I waited 5 mins and was able to drive around the parking lot for a min before it happen again.
    What could cause something like this?
    98 GTP - Retired
    86 Fiero GT - L67 | VS Cam | Polished GenV | Headers to 3" Catback to dual/dual Tips | 42.5# | N*
  2. #2 Re: Lost transmission? PLEASE HELP
    its over johnny. put a fork in her.
    hows the fluid look? is it burnt up and stinky now?
  3. #3 Re: Lost transmission? PLEASE HELP
    MD
    No the fluid is actually clean looking.
    98 GTP - Retired
  4. #4 Re: Lost transmission? PLEASE HELP
    idk, its never good when it looses all gears, but comes back for a bit after it cools off. then fades a way again.
    most of the time when you see this it is pretty much new tranny time. or used.
  5. #5 Re: Lost transmission? PLEASE HELP
    MD
    Yeah trans is toast, I just pulled a low mile rebuilt one for cheap.. Just gotta wait for the weather to be nicer.
    98 GTP - Retired
  6. #6 Re: Lost transmission? PLEASE HELP
    GT Level Member dezebe1's Avatar
    May 2013
    Dallas TX
    it's your torque converter going bad. Had the same thing happen to me 3 years ago in mine. Pull the pan and you'll see metal flakes in the bottom
    Team JB-Weld
  7. #7 Re: Lost transmission? PLEASE HELP
    MD
    Quote Originally Posted by dezebe1 View Post
    But it's still worth swapping in the used tranny I got too right? it had to cause other damage.
    98 GTP - Retired
  8. #8 Re: Lost transmission? PLEASE HELP
    Dec 2012
    Where 4T65E's were born
    Clean the cooler and lines out real well
    Sold.
  9. #9 Re: Lost transmission? PLEASE HELP
    May 2013
    Dallas TX
    ^just like he said, need to flush the cooler lines and cooler in the radiator. after that you should be good to swap, pull the pan on the used trans and inspect it then change the filter and put in fresh fluid
    Team JB-Weld
  10. #10 Re: Lost transmission? PLEASE HELP
    MD
    Well the old tranny I took drained and took apart, there was metal shavings like CRAZY, it was overflowing the magnet, pouring out of the torque converter, etc. Haven't been getting off work early enough to finish up before dark, but I just have to put the wheels on and add fluid at this point to my "new" used tranny....
    Upon inspection of the new tranny the fluid was very freaking clean, whole tranny was very clean and the magnet had barely anything on it.. So maybe I got lucky at the pick and pull yard? If it works then I will say I got a good deal for $130 for tranny at pick and pull yard, I spent more than that on the new converter.
    New "used" tranny I got in now...
    98 GTP - Retired
  11. #11 Re: Lost transmission? PLEASE HELP
    Dec 2012
    Clean the cooler lines?
    Sold.
  12. #12 Re: Lost transmission? PLEASE HELP
    for sure back blow the cooler lines add more fluid and flush the lines. this metal chips and flakes can hide in the cooler. it dont take much for them to hurt that clean new/used baby.
    maybe a shift kit too before the pan gets put back on.
  13. #13 Re: Lost transmission? PLEASE HELP
    MD
    I blew out the cooler on the rad and swapped in different lines (my gtp is a 98 and the tranny came from a 02~ so the line fittings were different too).
    98 GTP - Retired
  14. #14 Re: Lost transmission? PLEASE HELP
    MD
    Well drove it like 50 miles so far.. Everything looks to be good with this trans.
    98 GTP - Retired
  15. #15 Re: Lost transmission? PLEASE HELP
    awesome.
  1. lost 4th
    By zach101 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-05-2013, 05:16 PM
  2. Need some Transmission Repair Advice - Lost Drive and 3rd
    By dlofx in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-13-2013, 12:14 PM
  3. I'm lost here, please help
    By Juanmiguel in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-18-2011, 08:06 PM
  4. im lost here
    By sven101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-06-2010, 04:07 PM
  5. car lost 4th
    By Joe m in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 02-03-2010, 10:08 PM
