Thread: Trans stock cooler line replace/fluid loss?
Results 1 to 5 of 5
  1. #1 Trans stock cooler line replace/fluid loss?
    Nov 2012
    Madison
    So I noticed some grime on the cooler lines, and wiped them clean yesterday. Today I checked and could see pink on the lower one(viewed from top) at the metal crimp connector.
    The top isn't leaking. yet .... The line also looks slightly corroded around the plastic radiator clip that holds them.
    Well my question is how much fluid is lost when changing those. They could wait until I do a pan drop since they aren't even making a drop on the cardboard monitor.
    I am just trying to do the math on the amount.Will I need to have more than 8 quarts handy?
  2. #2 Re: Trans stock cooler line replace/fluid loss?
    You might loose a cup of fluid total if that, while changing the lines.
  3. #3 Re: Trans stock cooler line replace/fluid loss?
    if you change both lines and drain the cooler ( its gonna drain with no lines) your looking at a quart extra, maybe a bit more.
  4. #4 Re: Trans stock cooler line replace/fluid loss?
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    When we did ours, if I remember right. We didn't lose a whole lot of fluid mainly what was in the lines and the rad, but by the time re replaced our it was losing lots of fluid everyday. I would guess having an extra quart handy would be good. I know buying 2 gallons of fluid was cheaper than 8 individual quarts.
    2012 F150 STX
    - Gonna be a race truck
  5. #5 Re: Trans stock cooler line replace/fluid loss?
    Nov 2012
    Madison
    Thanks guys!!!
    I picked the Oreillys dex 6, 8 quarts because it was the cheapest way.
  1. Trans Cooler Line Help
    By robrileyw in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2021, 01:26 AM
  2. Need help on cooler line issue - upgrading to a GTP trans
    By harner in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 09-04-2012, 04:04 PM
  3. What to replace radiator trans cooler lines with barbed fittings. Which to buy?
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-17-2011, 11:10 AM
  4. Trans Cooler Line Leaking
    By johng80 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-19-2011, 12:05 PM
  5. trans cooler line leaking
    By _nick_ in forum General Tech Discussion
    Last Post: 09-21-2011, 09:58 AM
