Depends on how many shavings are floating around in there.
I'd recommend not driving it until you replace the Diff to avoid a bigger issue.
-Rob
you doñ need to replace the diff per say... pull both cv shafts and pull the diff cover. then pull the diff out if the pin just came out go to autozone, look in the help aisle and youll find roll pins.
not sure about the dorman pack i used the help assortment and found am identical one
i bought a new one at the dealer for like $3 once. Yea I wouldnt drive the car at all with nothing holding the diff cross pin in.
Well i got the pin. Im going to be ripping it apart tomarrow morning cus i dont have to work till 5. Is there anything else im gonna need besides the pin and the fresh fluid? Like a gasket? Or is there a write up anywhere on this? Now say i do need as new diff they are all the same correct? Like i can rip one out of any hd trans and it will work 98+? Mines an 04 compg.
