Thread: How Long Will A Shift Kit/Trans Cooler Give Me ??
Results 1 to 10 of 10
  1. #1 How Long Will A Shift Kit/Trans Cooler Give Me ??
    May 2012
    Bloomington, IN
    I have a 2004 N/A GP with 171k on it. I developed some occasional hard shifting which I attributed to a PCS issue. The problem would fix itself once I turned off the car relieving the pressure (I believe/read somewhere). Added some Lucas Oil and that more or less eliminated the problem. A few months later I decided to change the fluid and filter for good measure. I added a full bottle of Lucas Oil as well. Shifting was dramatically improved after.
    Recently though its been hard shifting again. However, it is not nearly as bad as before, only a fraction of the harshness I had previously. I haven't had the trans codes read yet, but i'm guessing a P1811 code. Regardless of the code, I assume I'm looking at a high labor rate whether its the PCS or worn clutches per the information at tripleedgeperformance.com (a few hours away from me).
    I don't mind swapping out the trans if that's the case, I imagine cheaper than a rebuild. My biggest question though is if I did install a TransGo shift kit and/or trans cooler what kind of mileage life will I get out of them before I need a another trans?
    I'm not looking for an exact mileage but a ball park figure, if anyone can give me an idea. Please let me know if you have any thoughts, it's
    appreciated!!
  2. #2 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    got a magic 8 ball? that shift kit and fluid change seems to help out with the hard shifts, and the cooler is always a good thing to have. but you never know in the end till it goes.
    171 is rather high miles for any trans is left un serviced over the years.
  3. #3 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    Jul 2012
    Chicago
    171k is up there. But shift kits do wonders.
    -Carl
  4. #4 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    Feb 2010
    TN
    So my trans with 328,000 (1997 GT N/A)and being serviced every 60,000 would not be hurt by adding a shft kit, it prolong it's life. Seems to work ok now.
  5. #5 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    Quote Originally Posted by Logan541 View Post
    god thats a winning trans
    if your fluid still looks nice and red i'd do it.
  6. #6 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    mine had 230K on it when i parted it due to rust. Trans loved shifting into 2nd chirping tires
  7. #7 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    Jul 2010
    Coquitlam,BC,Canada
    I'm coming up on 3 years (70,000km / 44,000 mi) since installing my shift kit; she still acts and runs the same.
    Who knows how long the band-aid will last.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  8. #8 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    Feb 2010
    TN
    Quote Originally Posted by Bronco Boy View Post
    But mines already running good I wonder if I should leave well enough alone
  9. #9 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    Jul 2010
    Coquitlam,BC,Canada
    I'd say do it. You don't know how good/bad your PCS is, and it could cause you issues tomorrow. Band-aid it now and you may never have any issues.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  10. #10 Re: How Long Will A Shift Kit/Trans Cooler Give Me ??
    May 2012
    Bloomington, IN
    Yeah already ordered the parts, thanks for the input
  1. Trans cooler for GXP
    By Rnungaray08 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-29-2017, 06:45 PM
  2. Just Ordered Transmission Cooler and TRANSGO Shift Kit (UPDATED!)
    By lattyd in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2012, 11:40 AM
  3. Trans takes a long time to shift from 1st to second, one it does it is good
    By hampshire32000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-09-2011, 03:47 PM
  4. trans cooler and oil cooler
    By mhartwig in forum General Tech Discussion
    Last Post: 11-17-2010, 10:33 PM
  5. trans cooler?
    By boostedgtp2003 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-02-2010, 08:45 PM
