Thread: Transmission jerks between shifts at low speed.
Results 1 to 6 of 6
  1. #1 Transmission jerks between shifts at low speed.
    Apr 2013
    White Lake
    2005 GP GT 122k Miles.
    I've noticed this happening twice now in the past 2 days... I was on the express way both times and it was bumper to bumper for a long time. When I would stop then start to go, when it shift's it would jerk my car "between 5-10 mph". It would happen ever single time I would stop and go and accelerate very slowly. I'm no mechanic but could this be my torque converter locking up?
  2. #2 Re: Transmission jerks between shifts at low speed.
    GTX Level Member 2007GPGTSC's Avatar
    Nov 2013
    Des Moines, IA
    probably throwing the P1811 code first you need to check the fluid, if its nasty, burnt, has glitter in it, its time for a drop n fill ect. also have it scanned with a code reader and look for the P1811 - hard shifts caused by shifts taking too long (longer than .6 seconds or something)(worn clutches) which results in the pcm commanding max line pressure .... making shifts harsh/hard.. its kind of a fail safe the pcm is trying to prevent damage
    2007GPGTSC
    mods : HAI, PLOG, 3in DP , TG Shift Kit, AL 605's, POLY DB's
    Quote Originally Posted by 2007GPGTSC View Post
    " sad thing is "
  3. #3 Re: Transmission jerks between shifts at low speed.
    Apr 2013
    White Lake
    Fluid was changed about 7k miles ago and before that I wasn't burnt. I also had my transmission scanned twice with 0 codes found at 2 different transmission shops. =/
  4. #4 Re: Transmission jerks between shifts at low speed.
    GTX Level Member hensleya1's Avatar
    Jun 2013
    Beavercreek, OH
    After being bumper to bumper a long time implies a heated up trans, especially with no incoming air to cool it. Could be a bad pcs solenoid. You might be able to alleviate this with a tune or independent trans cooler, keeping the trans from ever reaching those high temps.
    2003 GT Limited Edition 199k - The $600 winter beater.
    2004 Buick LeSabre 172k - Top Swapped, 3.5 pulley, 1.9 rockers, SLP headers... still slow...
    MAKE AMERICA FAST AGAIN!
  5. #5 Re: Transmission jerks between shifts at low speed.
    Apr 2013
    White Lake
    I guess a tune and trans cooler would be a good idea... I was wondering though, I know the GTP's can display trans temp on the display but on the regular ones it does not. I have hooked up a OBD and torque app to see if I can read the trans temp but nothing happened. Anyway I can make it to where it will show what my trans temp is?
  6. #6 Re: Transmission jerks between shifts at low speed.
    Nov 2013
    Des Moines, IA
    Aeroforce Scan Gauge should get ya there
    2007GPGTSC
    " sad thing is "
  1. Transmission jerks when car gets warm
    By Snapper in forum Introductions/Noob Questions
    Last Post: 03-15-2013, 05:18 PM
  2. Car Jerks at WOT
    By Joshmoshh in forum General Tech Discussion
    Last Post: 01-31-2013, 11:43 AM
  3. Sloppy Transmission Shifts, HELP!!
    By brandonl2000 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 10-01-2011, 12:40 AM
  4. transmission hard shifts when hot
    By ya61x in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-23-2011, 01:46 PM
  5. transmission shifts better after rack and pinion swap
    By Scottydoggs in forum General Tech Discussion
    Last Post: 06-17-2011, 12:40 AM
