Quote Originally Posted by 2003 SSEi View Post
not entirely true.
Some cars have Internal Range Switches, and some have the External Range Switches. You will need to find the correct one for your car as the connectors are different. The way to tell?? Look for a large black box where the shifter cable is
Also there are different trans fitting sizes. Some of the early cars have a check ball in the fitting and the later years have the check ball inside the valve body
if your tranny has the internal, and the used one is external, you can swap it around, or the other way around.
tranny lines are easy enough get around.
