98 GTP, 120k, intake, DHP v1.0, nothing major done to the car obviously. Was previously having TCC issues, seem to have cleared up with the DHP ecu and and about 8oz seafoam transfix or whatever it's called. Fluid looks good, smells good. Don't know much maintenance history.
Wife got stuck coming through the snow that the plow pushed across the drive way. Got the car through and into the driveway. Driveway was ice and I'm guessing she might have over spun the tires and hit a dry patch. Though she denies it (go figure.)
The car moves back fine, rolls in neutral freely. When put into D, 3, 2 or 1 the car won't move unless some of that right pedal is given. When trying to move the car lurches about 4 inches, stops, 4 inches, stops all while for lack of better terms, clunking. When viewing from the outside with the car killer behind the wheel it seems to be binding the passenger side wheel. If it wasn't 27 degrees outside and I didn't have another fabulous GM product (project?) in the garage I'd dig a little deeper before posting.
I checked the fluid with the car off hoping to maybe find some tell tale glitter, no dice. BUT...with the vehicle OFF the fluid was super high on the dipstick. Not sure if that indicates a pump problem or not.
Either way, some professional insight would be great (for me and the car...have you seen my meds?)
Thanks in advance.
Doc
