Thread: Comp G trans swap Question
Results 1 to 9 of 9
  1. #1 Re: Comp G trans swap Question
    Mar 2013
    Colorado - USA
    It worked for me. The only problems that I might not be able to forecast would be differences between your 2001 and my 1999.
    The only snag that I had was my 1999 cooler lines couldn't be connected on the trans end. I had to buy new cooler lines for the 2000-2003 GTP: AC Delco P/N 10330105 & 10330106. But you've got that covered.
    The biggest surprise came during the test drive when I discovered that all of the manual ranges were fully functional. I wasn't expecting that.
    And what ever you do - Do NOT forget to connect the pig-tail to the REAR Knock Sensor before you connect the motor to the trans!
    Hit me up if you run into a snag.
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  2. #2 Re: Comp G trans swap Question
    Mar 2013
    Colorado - USA
    What year is that trans? And what kind of deal are you getting on it?
  3. #3 Re: Comp G trans swap Question
    Sep 2012
    Ames, Iowa
    Quote Originally Posted by Shmoke View Post
    PM'd
  1. Comp G an HD trans?
    By gotgtp in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-16-2012, 08:00 AM
  2. Trans swap question
    By fleck24 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-03-2012, 08:24 AM
  3. Trans Swap Cost Question
    By ljmonnin12 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-12-2012, 05:53 AM
  4. 05 prix comp edition trans fluid temp question
    By tznitup in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-03-2011, 12:40 AM
  5. Comp G trans in a non Comp G
    By Explicit_Spade in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-08-2011, 10:31 PM
