Thread: broke a flex plate mounting bolt
Results 1 to 16 of 16
  1. #1 broke a flex plate mounting bolt
    Sep 2013
    Iowa
    Any one think this will be an issue? 1 of the 8 bolts is broken off in the crank.
  2. #2 Re: broke a flex plate mounting bolt
    Mar 2013
    Colorado - USA
    Pretty Big deal in my book. Try to get that out of there. It shouldn't require much torque to remove it since the head is missing - you might get lucky and simply twist it out with a scratch awl or something similar.
    If that doesn't work:
    I'm almost positive that bolt is made with high-strength steel so use a cobalt drill bit - left handed twist if available - and an Easy-Out to remove it.
    PS: Use penetrating lube
    E85 L32 S1X Heads 105#Crow Springs LQ4 2k+NStarTB Deka 60# Gen1 SLP Headers Stock Plugs
    19 deg GFS and ZERO KR@14 PSI <10% LTFT
    GMPP Struts/Springs SLP Sway Bars Z06 Brakes
  3. #3 Re: broke a flex plate mounting bolt
    Donating Users GMR Badass's Avatar
    Apr 2011
    Columbus, OH
    Quote Originally Posted by Shmoke View Post
    I think you have a misunderstanding of the definition of torque. Just because the head is missing does not mean that it will require more or less torque to remove.
    To the OP: I wouldn't run it without out and would work on getting the rest of that bolt out.
    I would remove remaining bolts and take off the flex plate, then weld a nut to the remaining portion of the snapped off bolt. If you don't know what I mean by the look it up on youtube and you'll see exactly what I'm talking about.
    1999 GTP 2dr - Whipple 537whp.....for now
    1998 GTP 4dr - ST2, Cartuning PT61, IC - SOLD
    1999 GTP 2dr - SIX, GenV, Headers, TEP Trans, E85 - SOLD
    1997 GTP 4dr - 3.4, 1.9's, 3" DP, P-log - SOLD
  4. #4 Re: broke a flex plate mounting bolt
    GTP Level Member LeadfootCJ7's Avatar
    Oct 2012
    Houston, TX
    You need to get it out and replace it. I would go with a easy out to remove it as mentioned above.
    2007 Grand Prix GXP;2002 Camaro Z28 - tune, CAI, and exhaust
    2006 GMC 2500HD - ATS high flow manifolds and uppipes, turbo back exhaust, blocked EGR, Denali headlights, Reflexxion Cown Hood
    1994 Olds Cutlass Supreme 2 door
  5. #5 Re: broke a flex plate mounting bolt
    GTP Level Member tms8582's Avatar
    Washington Michigan
    Just wondering how it broke? Did it break by itself or did you over torque it putting on a flex plate? I put intense bolts in mine with red lock tight and tightened to 30 lbs. I think the directions actually said 25 lbs which seemed awfully light to me so I just went a tad over. I was surprised how "loose" those bolts are specd to go in. Im not sure what the stock bolts are specd for but I bet its less than you'd think by feel.
    Stage 1 Comp Cam / 105 Springs / Yella Terra 1.7's / SLP Headers / Ported heads / 255 Walbro fuel pump / Siemans 60# Injectors / 2.8 Pulley / 180 stat, 104 AL's / Intense e85 tune / 3" ZZP exhaust / GXP seats / KYB Coilovers /
  6. #6 Re: broke a flex plate mounting bolt
    Sep 2013
    Iowa
    Broke when torquing
    Book said step 1 to 11lbs then step 2 go 50 degrees more. Heard it break.
    Guess when I get back to it i'll have to just take it apart and get a new bolt. I was hoping with the other 7, 1 missing wouldn't be a big deal. Maybe it would though.
  7. #7 Re: broke a flex plate mounting bolt
    GT Level Member DJNight2k's Avatar
    Lorain, OH
    Stock are torque to yield, 11 lb/ft then 50 degrees additional and to add to everyone else's suggestions, yes get it out and replace it. I would not run it with one missing. As long as it was not cross threaded in, it should come out relatively easy like others have said. I would replace all the bolts when you do get it out for peace of mind depending I guess on how that one broke. were you installing it and over tightened or was it broken when you found it etc.
  8. #8 Re: broke a flex plate mounting bolt
    SWPA
    The real question is, why would you even risk it? Everything is apart now to where you can get to it. If the flexplate cracks now you have to pull everything back apart and replace not only the broken bolt, but now the flexplate.
  9. #9 Re: broke a flex plate mounting bolt
    Sep 2013
    Iowa
    I'll be able to get back to it tomorrow and get it out and replace the bolts
  10. #10 Re: broke a flex plate mounting bolt
    Mar 2013
    Colorado - USA
    Quote Originally Posted by GMR Badass View Post
    No I don't. And yeah it does dude.
  11. #11 Re: broke a flex plate mounting bolt
    Kansas
    Let us put it this way. It depends on the threads of the bolt, threads and pitch it gets threaded into, quality of metal of the bolt, and just how much torque he had on it when he put it in. Yes the head being removed will help reduce some of the torque stretching the bolt, but still can be a PITA to remove.
  12. #12 Re: broke a flex plate mounting bolt
    He might misunderstand, but his explanation is good. Once the head is gone, the pressure on the threads is gone. I've used a small punch or chisel to tap these out a few times. It happens.. tap the edge counter clockwise and get new bolts to start with if you want to torque them properly.
  13. #13 Re: broke a flex plate mounting bolt
    Mar 2013
    Colorado - USA
    There is no misunderstanding here. Torque must be applied however small or large, to what remains of the broken bolt in order to remove it. Where's the misunderstanding? If there's any misunderstanding on my part, it is how a broken bolt could be removed without the application of some level of twisting force.
    Sometimes a left-handed drill bit will snatch inside the bolt shaft as your're drilling it and it will simply spin out. That's what I expect would happen in this case and why I always use left handed cobalt drill bits on broken bolts. If it doesn't come out that easily, then an Easy-Out would definitely work. But in any case use a good penetrating lube and a steady hand.
    Wondering how things worked out for the OP?
    Mercer, Pa
    Best trick I ever learned was get a air pencil, the kind used for engraving into metal parts. It has a carbide tip and vibrates. It will spin broken bolts out with ease as long as the bolt broke from over torque. Won't work if bolt broke from being bottomed out in a blind hole or cross thread.
  15. #15 Re: broke a flex plate mounting bolt
    Sep 2013
    Iowa
    All is well. It came out fine. I have easyouts so i just drilled it and it backed right out.
  16. #16 Re: broke a flex plate mounting bolt
    Shmoke, I was aiming that toward Greg, not you. I was on the same page as you.
  1. flex plate
    By Eric Whitter in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-31-2013, 09:52 PM
  2. Caliper Mounting Bracket Bolt
    By Paintball0027 in forum Brakes/Suspension/Chassis
    Last Post: 10-28-2010, 11:14 AM
  3. bolt broke off mount brackets to block,where can i find new bolt
    By crystalterry89 in forum General Tech Discussion
    Last Post: 10-21-2010, 06:28 PM
  4. flex plate
    By tihosick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-10-2009, 10:25 AM
