Thread: Trans rebuild kit for HD
Results 1 to 14 of 14
  1. #1 Trans rebuild kit for HD
    Banned
    Jan 2013
    Colorado
    Is there a rebuild kit offered for the 4T65E-HD transmission? On rock auto I can only seem to find some for the regular transmission not the HD one.
  2. #2 Re: Trans rebuild kit for HD
    Nov 2011
    NY
  3. #3 Re: Trans rebuild kit for HD
    Really isn't much of a difference.
    The only real difference is the differential.
  4. #4 Re: Trans rebuild kit for HD
    Banned
    Jan 2013
    Colorado
    Which ones are for the HD trans?
  5. #5 Re: Trans rebuild kit for HD
    Nov 2011
    NY
    Call TEP and talk, let em now what you want to do, what mods you plan, etc., and I'm sure they'll give you what you need.
    But like I said previously, on this I wouldn't venture. I'd just get the tranny all done and call it a day, but to each their own.
  6. #6 Re: Trans rebuild kit for HD
    Banned
    Jan 2013
    Colorado
    What do you mean you wouldn't venture?
  7. #7 Re: Trans rebuild kit for HD
    Nov 2011
    NY
    DIY tranny rebuild...
    I wouldn't even though I'm sure I could if I wanted to.
    I'd let TEP do it and be happy! They know the tranny's, know what to look for that needs to be replaced/upgraded and will do it right. It's just my $.02
  8. #8 Re: Trans rebuild kit for HD
    Apr 2012
    Bancroft. Ontario, Canada
    Quote Originally Posted by coolone View Post
    I bet you know "trannys" pretty good too lolololol
    God that was too good to pass up lol
    But yeah, unless your really mechanically inclined, and know EXACTLY what your doing, then build your trans yourself.... IF NOT, call TEP, and have them build your transmission up..
  9. #9 Re: Trans rebuild kit for HD
    The difference between the physical transmission from HD to nonHD is the diff, length of output shaft, drive and driven gears along with the proper lube scoop. That's it. Nothing different from a rebuild kit perspective.
    If you want to build one, it's not bad. There are a few things I'd suggest you have done for you. Otherwise unless it's a basket case.. basic tools plus a couple of things will get the job done.
  10. #10 Re: Trans rebuild kit for HD
    Banned
    Jan 2013
    Colorado
    Well the knowledge too is helpful which I'm not entirely sure I have. What things do you recommend bill?
  11. #11 Re: Trans rebuild kit for HD
    Depends on how much you farm out.
    I'd automatically suggest having TEP do the channel plate and valve body. Most trans places don't have the tools to put in the fixes/upgrades, TEP does. For what it comes with..it's very reasonably priced.
    Clutch compression tool
    input/3rd housing teflon seal resizer - or have TEP do them
    An engine stand with a bracket (easy to make if you have a welder handy)
    From there it depends if you need to replace bushings etc.
  12. #12 Re: Trans rebuild kit for HD
    Banned
    Jan 2013
    Colorado
    Well don't have a compression tool or welder. And I wasn't necessarily interested in mailing my trans somewhere.
  13. #13 Re: Trans rebuild kit for HD
    Banned
    Jan 2013
    Colorado
    I think I might do the engine build, replace the trans filter, then find a shop to do the transmission (also replace the converter)
  14. #14 Re: Trans rebuild kit for HD
    Jul 2013
    Antioch, CA
    I know how to do a trans rebuild, but I hate doing it. Takes me forever and I need a huge space to do it, I'd do it myself if there was no other option. I plan on getting one from TEP when the time comes.
  1. Rebuild fail or trans?
    By Overboost101 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-30-2012, 12:17 PM
  2. Trans rebuild
    By Logan541 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 08-13-2011, 04:06 PM
  3. Trouble with new trans rebuild
    By andante147 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-28-2011, 08:29 AM
  4. Can I rebuild my Trans????
    By timboku in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 04-17-2010, 01:55 PM
  5. Looking for Trans Rebuild Info
    By JoeMama in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-19-2008, 12:03 AM
