Thread: New transmission break in
Results 1 to 9 of 9
  1. #1 New transmission break in
    GT Level Member Nighthwk12's Avatar
    Nov 2009
    Central Jersey
    SO I did a full rebuild on my 4t65e-HD. New steels, clutches, bushings, solenoids, VB/CP upgrades, the works (I pretty much cloned TEP street/strip). Now what is there for a break in procedure? Should I change the fluid and filter after 500 miles? Should I lay off of it or give it the juice every once and awhile to seat everything?
    Thanks
    97 Bonneville SE Not so much a 97 anymore
  2. #2 Re: New transmission break in
    I would let it row through the gears as much as possible...for SURE keep an eye on trans temp.
    And yeah, I would do a pan drop in a few hundred miles.
    I had Dave build a trans for my blue car, I did a pan drop and filter change around 1k~ miles. Then I beat the ever livinig piss out of it. Worked fantastic
    Hope this helps.
  3. #3 Re: New transmission break in
    Nov 2009
    Central Jersey
    Yep very. Most driving of 0-55-0 driving so going through the gears are no problem. I was hoping slightly a pan drop was in my near future. I want to use my pan with the plug (dorman pn#265814)
  4. #4 Re: New transmission break in
    GTX Level Member acidcrashdburnd's Avatar
    Apr 2012
    Middletown DE
    I just put mine back in the car with all TEP parts and a cooler and have been beating up on it.
    Transmissions either work or dont work.
    2005 GPGT- Top Swapped Click me! 15.5 @109
    2002 GPGT- slow and stock
    1993 Oldmobile 88
    - exploded the diff @158k
    GPF Resident Flowmaster Troll
  5. #5 Re: New transmission break in
    GT Level Member 00grandprixgtp's Avatar
    Apr 2009
    Elkhart
    i did the same rebuilt it and drove the piss out of it then after like 1k did a pan drop to see if everything looked ok
    2.4Pulley, Ngk Tr7 plugs, Self tune, Methanol injection
    23.5 deg timing gen v,78mm billet tb , Poly dog mounts, Sd headers
    Zzp s2 intercooler ,UD wp pulley,is2cam,130# springs modded retainers
    P&P heads and lim built trans 3.29 gears harden parts 2500 stall shift kit
  6. #6 Re: New transmission break in
    When Dave sends a trans.. the instructions are basically to fill X, check it.. top.. drive a little .. check top and that's all. There's really no break in there's no need to change a filter in short mileage. The only things that should be on the filter or in the pan are the slightest bit of clutch material.
    I put my new trans in, drove a year ~30K and did a pan drop service. I plan the same in about another 8 months. =0) motor on and smile.
  7. #7 Re: New transmission break in
    Mar 2012
    South Beloit, IL
    How much did you spend all together on parts for this rebuild and how long did it take? Thanks.
  8. #8 Re: New transmission break in
    Apr 2012
    Middletown DE
    1993 Oldmobile 88
  9. #9 Re: New transmission break in
    Nov 2009
    Central Jersey
    Quote Originally Posted by Nchristopherson View Post
    I had to replace some parts a normal rebuild doesn't need like the pan, 2nd clutch spring, and pump.
    With Everything and a Torque converter ($110) it came out to $830.
    But as I have said I touched everything and pretty much cloned TEP street strip trans without the 7/8 chain and 330M Shaft.
    Time spent on rebuild probably close to 30hrs (a lot of carnage to clean up)
  1. help break transmission
    By automech01 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-06-2012, 05:01 AM
  2. What did i break?
    By NR92 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-22-2011, 08:30 PM
  3. First Break down
    By Panther427 in forum 5.3L V8 (LS4)
    Last Post: 02-05-2010, 01:24 AM
  4. Break n oil
    By TorqueAutoMotiv in forum Off Topic Discussion
    Last Post: 11-13-2009, 11:27 PM
  5. not new but took a break
    By WhiteDevil in forum Introductions/Noob Questions
    Last Post: 10-06-2009, 07:59 AM
