Thread: tran scan--Please help
Results 1 to 3 of 3
  1. #1 tran scan--Please help
    Donating Users Mr D's Avatar
    Nov 2011
    Chicago
    03 GTP, 135k mi--L67 MN7. I've been dealing with the slip-bang/slow shift. Installed TEP shift kit, Lucas... Helped, but problem is back. I've used Torque for Android, logged and created chart. I am hoping someone will help me understand readings, ie what is normal, what are 'red flags', what readings/sensors can help diagnose our trans, etc. I am not very good with spreadsheets, this is my 1st pass. I can also add values for: trans fluid temp, TC slip speed, engine RPM, others. Ultimately, I'm trying to diagnose--If problem is PC solenoid/ TCC solenoid/ Shift solenoids, I'll do work myself--If problem is not solenoids (like torque convertor itself or damaged hard parts) I need other arrangements-- save $. THANKS in advance.http://i1172.photobucket.com/albums/...ps321d8e6e.jpg
    The problem that's causing the issue is right there between the seat and steering wheel. It's you
  2. #2 Re: tran scan--Please help
    Did you put in the transgo shift kit?
  3. #3 Re: tran scan--Please help
    Nov 2011
    Chicago
    Yes, Transgo-Go, as sold by TEP. with Lucas Transmission Fix Stop Slip. It helped, immediate improvement, but now its pretty bad again, esp. when hot. Planning a road trip for dad's day...
  1. 2004 GT2 Gas Hand/Tran/ABS
    By DMPsixes in forum Introductions/Noob Questions
    Last Post: 12-13-2012, 02:15 PM
  2. tran problem
    By jimjackson in forum Introductions/Noob Questions
    Last Post: 11-05-2012, 09:41 AM
  3. About to buy '07 tran for my '99 GTP ???
    By 90210GTP in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 03-22-2011, 08:44 AM
  4. 97 gtp tran problem
    By ibanez0110 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-04-2008, 01:37 PM
  5. 98gtp Tran Swap! (pics)
    By FoSHO99 in forum Pre-1996 4 speed Automatic (4T60E)(4T60E-HD)
    Last Post: 08-01-2008, 07:04 PM
