Thread: '05 GT Tranny slip when hot question
Results 1 to 14 of 14
  1. #1 '05 GT Tranny slip when hot question
    Aug 2012
    DC
    I have just the regular 3.8 in my '05 GP GT2
    I know its a matter of time before something happens with the trannies in these - wanted to get some input on possibly how close I am to the end
    I have 101K miles on the odo right now.
    For the most part when starting out nothing much happens - occasionally a 1-2 slip but usually ok.
    As the temp rises (per the DIC) thats when the fun starts. Over 175F degrees and the 1-2 bang happens under moderate acceleration. Once the tranny goes above 205F (ie, stop and go traffic) I can get bangs on almost all gear changes.
    The tranny temp has never gone above 228F - but in traffic it usually hits 205F no problem.
    The tranny fluid was exchanged about 15K miles ago so it should still be good.
    Any short term fixes or am I coming around the last bend with this tranny?
  2. #2 Re: '05 GT Tranny slip when hot question
    Johnstown, NY
    Short term fix I'd suggest a shift kit and aftermarket trans cooler
    98 Red Coupe Grand Prix GTP : 180* T-stat, U-Bend delete, NGK TR55's, SLP Catback
    My Ride: http://www.grandprixforums.net/jevik...upe-73301.html
    A must read for modding: http://www.grandprixforums.net/safel...0-a-67580.html
  3. #3 Re: '05 GT Tranny slip when hot question
    Feb 2013
    37.295091, -121.930053
    may sound like a dumb question but is it low on fluid?
    im a cookie again yay me
    please learn to forum better.
    ^^new favorite quote
  4. #4 Re: '05 GT Tranny slip when hot question
    If something is going to help it. It would be a shift kit in the accumulator only and one bottle of lucas stop slip. Seems to be a good band aid for the P1811 Max Adapt code you are likely getting.
  5. #5 Re: '05 GT Tranny slip when hot question
    Aug 2012
    DC
    BillBoost37,
    Im not getting any codes yet as I have a reader. After I got the tranny fluid exchanged the dipstick was 'full' - can I add a bottle of Lucas Stop Slip to this or would I have too much fluid in the tranny?
    Any suggestions on a good shift kit?
  6. #6 Re: '05 GT Tranny slip when hot question
    Johnstown, NY
    Transgo shift kit.
  7. #7 Re: '05 GT Tranny slip when hot question
    Aug 2012
    DC
    Quote Originally Posted by Jevik View Post
    Transgo shift kit.
    Thanks for the link - it shows for 1981-1988 Pontiacs - is that the correct one?
  8. #8 Re: '05 GT Tranny slip when hot question
    Johnstown, NY
    Quote Originally Posted by goochman View Post
    I didnt link anything o.O
  9. #9 Re: '05 GT Tranny slip when hot question
    so you had the trans flushed? if so you killed it for sure.
    never flush these trannys if they have not had regular servicing over it life. if you were to flush the trans, you want to do it from 30,000 to 50,000 miles depending where you live hills wise. flat lands you can go longer to 50,000.
    do the shift kit, filter, and the bottle of lucas with the 7 new quarts of tranny fluid. then pray some.
  10. #10 Re: '05 GT Tranny slip when hot question
    Aug 2012
    DC
    I had the fluid 'exchanged' and not flushed - I know the high pressure flush can kill it, so it was just a drain and refill.
  11. #11 Re: '05 GT Tranny slip when hot question
    what the difference between flushed or exchanged, and flushed is not high pressure any thing, the trans does the pumping of the old fluid out, and sucks in the new fluid. at idle in park.
    if you changed all the fluid, more then a pan drop and filter change you flushed it, and killed it.
    if all they did was drop the pan and change the filter the trans should have survived, unless it was slipping before this service you had done, then for sure its on its way out.
    sadly people have a trans start to slip, then do a flush, and boom, its dead.
  12. #12 Re: '05 GT Tranny slip when hot question
    Aug 2012
    DC
    It was a pan drop - thats what I meant by exchange vs flush. That was over 15k miles ago before any slipping started so I dont think the 2 are related.
    Jevik - sorry for the confusion, the board system automatically created a link for that shift kit name.
  13. #13 Re: '05 GT Tranny slip when hot question
    Dec 2012
    Where 4T65E's were born
    Sold.
  14. #14 Re: '05 GT Tranny slip when hot question
    in that case id remove a quart of tranny fluid, and add a quart of lucas trans medic that stuff does work wonders. dont expect it to last forever, its a good band aid tho.
  1. Tranny question....
    By BigKev2403 in forum General Grand Prix Discussion
    Last Post: 03-21-2013, 10:15 AM
  2. Tranny question
    By goldgp in forum General Tech Discussion
    Last Post: 05-29-2011, 11:13 AM
  3. tranny question...of course.
    By twol8uluz in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 05-02-2011, 03:31 PM
  4. tranny question
    By mikedinthecity in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 11-09-2009, 05:09 PM
  5. question for tranny man
    By orangez34 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 12-12-2008, 11:58 AM
